Controlling an outletlinc from a switchlinc
I've added both my switch and outlet to a scene called Room Lamp.  I have set the switch to be the controller and the outlet to be the responder.  However when I turn the switch on or off nothing happens with the outlet.  Please help. Thanks.
Which outlet? What's plugged into the outlet?
It's an outletlinc that has a lamp plugged into it
There are three OutletLincs with different requirements. Which one do you have? What kind of bulb is in the lamp? Did you turn the lamp and verify that it is on before plugging it into the OutletLinc?
Sorry didnt realize there were multiple versions.  It is a 2473.  It has a lamp plugged into it.  The lamp does turn on and off with pressing the button on the outletlinc.
The only way I've been able to get the switchlinc to be able to control it is by using a program
If Switch is On
then Set Outlet On
else Set Outlet Off
Is this the only way to do it?
No, you should be able to control the On/Off Outlet using a scene. Click on the scene. Ensure that both the Outlet and the SwitchLinc are set to 100%. Select Tools > Diagnostics > Event Viewer. Set the level to 3 Device communications events. Right click on the scene and select Diagnostics > Scene test. Did the test succeed?
Edited by stusviews
Thanks for the help.  Not sure what happened, but when I went through the steps you described the test came back successful and the switch worked from then on.  Thanks again
