Scene, program, variable help needed
Problem: Rear spots are turning off when I am grilling.
I have a door sensor (triggerlinc) for a back patio door.  When the door opens I have the following program to turn on the rear spots.
             Control 'GR Door Sensor-Opened' is switched On
          Or Status  'GR Door Sensor-Opened' is On
    And From    Sunset  + 10 minutes
        To      Sunrise - 15 minutes (next day)
        Wait  2 seconds
        Set Scene 'Outside / Outside Rear Spots' On
I then have the following program to turn off the lights.  This is in case the lights are turned on by the switch.  I could use control so only the physical switch press will turn the lights off.  Would need to add a scene off to the else in the above program.
        Status  'Outside / Outside Rear Spots' is On
        Wait  15 minutes
        Set Scene 'Outside / Outside Rear Spots' Off
I have a green egg scene that is activated when I double tap a patio KPL button, which includes the rear spots.  So I was outside last night and then the spots turned off on me
        Control 'Great Room / Great Room Devices / GR Patio KPL - A Patio' is switched Fast On
        Wait  3 seconds
        Set Scene 'Outside / Big Green Egg' On
I have some disabled programs with a green egg integer variable.
        Wait  2 seconds
        $i.EggScene  = 1
and
             Control 'Great Room / Great Room Devices / GR Patio KPL - A Patio' is switched Off
          Or Control 'Great Room / Great Room Devices / GR Patio KPL - A Patio' is switched Fast Off
    And $i.EggScene is 1
        Wait  3 seconds
        Set Scene 'Outside / Big Green Egg' Off
        $i.EggScene  = 0
Do I just need to get rid of the third program.  Change the second program to:
        Wait  15 minutes
        Run Program 'Rear Spots Off if BGE =0' (If)
and then add this program
        $i.EggScene is 0
E
        Wait  15 minutes
E
IMHO this is your problem using status. It measures the device instead of the signal that identifies the source.
         Control 'Outside / Outside Rear Spots' is switched On
         Control 'Outside / Outside Rear Spots' is NOT switched Off
        Wait  3 hours
        Set Scene 'Outside / Outside Rear Spots' Off  <---switch already does this via load connection
Apparently you need to disable the off timer when you run the green egg scene (does that have something to do with ham :)
set the variable to 1 in the green egg program then include it in the timer program.
$i.EggScene = 1
Wait 3 seconds
and      $i.EggScene = 0
           Wait 15 minutes
Jon...
Edited by jerlands
Jon,
I was thinking I had to add a new program, the last one I had in my post, but I think the way you suggested should work fine.
Larry,
It is not really the issue of control vs status. If I just have a timer based upon the door sensor, then anytime I go outside that timer will run. That is why I think I need the variable to let the isy know that I am grilling or smoking (not cigarettes) and the rear spots should stay on.
Eric
Larry,
Eric
By changing it to a control trigger, you can select which device signal has turned it on and you can activate the off timer from only that trigger.
By sensing the status of the lights it doesn't matter what turned them on, they are going to turn off again the way your second program is written.
This seemed to be your complaint.
