Do you use "wait" between actions?
Trying to figure out how many of you use a "wait" time of any duration between actions in one program.  For instance, a program that changes the values of several variables and changes the temperature of a thermostat and maybe turns on some lights all in one program.  Do you just string the actions together or do you put a wait time of 1-2 seconds between each action or do you put a wait time only between certain types of actions such as after the temperature adjust but not after variable value changes or light changes.
Thoughts?
Shouldn't need a delay between variable changes unless they will drive insteon activity in other programs when changed.  I find it to be a good idea to delay between scene and device actions to allow time for ack/cleanup messages to happen before generating more traffic.
-Xathros
-Xathros
How much time between scene and device actions?
What about time between network resources call outs?
Edited by zerop
Between devices, 1 sec should do. After a scene with many devices in it, 3-5 seconds might be better.  I usually go with 1-2 between resource calls.  Network resource calls can and do queue up if things are busy. If doing variable substitution within the resource, it is possible to call a resource and have the variable change downstream in the programs before the resource is substituted and sent.  Where this is possible, you may want a longer delay. Just beware.
-Xathros
Edited by Xathros
I rarely use a wait between statements that involve Insteon devices, but I often need a wait when using network resources to control window coverings. The length of the delay varies. I experiment and then add one second to the shortest dependable wait.
