Scene or program, or both?
I'm new to Insteon, that will be quite evident in a minute. I'm playing around to understand the protocol and how it all works with ISY. I am wanting to setup a simple light on when motion is detected but only during certain times. Setting up a scene is very straight forward but simplistic in that the light will always go on with motion.
I am playing with a program but do the devices have to be linked with a scene first or with the authority for one device to control another be managed through the program? A very simple routine but I can't seem to get the program to function.
Suggest posting your Program.   Here is an example
Motion - [iD 0045][Parent 0001]
        Control 'MotionSensor2-Sensor' is switched On
    And From    10:00:00AM
        To      11:00:00AM (same day)
        Set 'SwitchLinc Relay' On
        Wait  20 minutes
        Set 'SwitchLinc Relay' Off
Looks like a difference in behaviour when using a switched on event vs. state on. Thanks LeeG.
Using a program to turn on a load introduces a delay. Use a scene. Select the MS, options. Check On commands only. Delete one line from the program. The light will come on sooner.
    And From    10:00:00AM
        Set 'SwitchLinc Relay' On <--delete this line
        Wait  20 minutes
Edited by stusviews
Welcome!
Not to throw too much at you at once but...
Here are some quirks for newbies that caught most of us and still does occasionally.
        Control 'MotionSensor2-Sensor' is switched On   <---will only trigger the Then section = no Off trigger with 'Control'
    And From    10:00:00AM
        To      11:00:00AM (same day)        <--- will trigger the Else section = turn the light off
        Wait  20 minutes
Else                      <--- be very careful using the 'Else' section with bracketed time frames (from-to), or status triggers
