Mobilinc and ISYPortal
I posted this in Q&A but it was suggested I post here.  I'm trying to get the Mobilinc App to work with the ISYPortal.  Is this possible? I can't seem to get it to connect.
Hi Bxsteez,
MobiLinc is not compatible with the ISYPortal. For portal service we have our own MobiLinc Connect portal for the ISY.
Wes
Hi Bxsteez,
Wes
Will MobiLinc Connect allow for Amazon Echo integration?
I dont see why UDI and Moblinc compete with each other.  Both have non compatible portals and now they each will have their own Echo skill?  Really?  Fragmenting the functionality and competing with each other rather than partnering and offering one system is hurting each companies business in my opinion.
I am not going to pay for two portals.  To be honest I am sorry I paid for the Mobilinc.  Yes they added a whole bunch of features recently but the basic functionality and GUI is still very poor.  But if I buy an apple watch and pay even more money it may work.
But what do I know I am just a customer.
Hello everyone,
We found the root cause if the incompatibility between MobiLinc and ISY Portal: MobiLinc is sending a poorly formatted header which includes the port number in the path.
We will put a fix in the portal to ignore the port.
We'll push to production as soon as we hear back from Amazon (lest we cause interference with their testing).
Hi Digger,
I don't call this competition. We are still working very closely with each other. It's just more choices for our customers.
Good catch! I'm sure allowing Mobilinc to work against the portal is going to be a significant benefit to many!
Hi dwessels,
Yes, it's live and working. What you need to do:
1. Login to ISY Portal
2. Click on My Profile (top right)
3. Set your preferred ISY and Save
4. In MobiLinc configuration, for https URL, type my.isy.io ... NO paths are necessary
Hi Michel,
Thanks for the quick reply.  I went ahead and set it up that way.
When I go to sync with the ISY, I end up with an error: "Network Error: There was a problem sending the request.  Please verify the connection setting in My Settings and try again. Error Code: 401. Error Message: Authentication needed"
I have the my.isy.io username and password in the app, and I have the https field set to my.isy.io and port 443.  Am I missing something else?
I logged into the portal to set the default ISY.
Hi Michel,
The instructions I have are to set https to my.isy.io, leave http field blank, input username and password for portal and select secure.  I believe the port field is ignored.
I'm running android and have tried everything I can think of but can't get it to connect.
Jon...
Edited by jerlands
Hi Guys,
Also, you have to change the profile from MobiLinc Connect to ISY. In short, MobiLinc should think that it's talk to ISY directly.
Here are my settings which don't work on my android...  I typically connect https thru a DDNS which has always worked well.
Host Type = ISY
User Name = Portal User Name = email address (also tried encoding @ to %40)
Password = Portal Password
Local http:// = blank
Local Port = 80 (n/a because I understand this is ignored?)
Secure https:// my.isy.io
Secure Port = 593 (n/a)
Connection Method = Secure Connection (HTTPS)
Jon...
Hi Guys,
Yes, it is setup to talk to the ISY directly.
try setting the secure port to 443.
I've tried 443 but to be certain tried again and no go... maybe something on my phone but works well with DDNS
Jon...
Hi Jon,
Can you login to https://my.isy.iodirectly? As suggested, the secure port must be 443.
Hi dwessels and Jon,
Do you already have a MobiLinc Connect account?
No.. It's problematic.  I can eventually log in but multiple entries, refreshing the page etc,..  I also get the error "email must be between 6 and 80 characters" so I tried encoding @ but no difference.  I'm thinking now it might be password related in that I use a 12 character word.  I'll change this and see what happens.
Edit: Tried the password change and no effect
Edit2: I may have mis_understood.  I can log in using my.isy.io but using email:password@my.isy.io in the URL no..
I don't have a mobilinc connected account
Jon...
Edited by jerlands
I will watch this thread as I would really like to use this. I had the ISY portal deactivated in less than a day after buying it because I rely to much on mobilinc and the ISY portal just doesn't work with mobilinc. My iPhone just hung on parsing address 18277 details...If I closed the app and relaunched it I was able to see some of my devices but they never showed status and they would only turn off, not on..
hopefully someone "fixes" this integration issue as it seems like mobilinc is the most popular way for people to use their ISY from their mobile devices.
On my android I use DDNS for https and have never had issues.  I'm only playing around with it now to get it working :)  I don't think you need mobilinc connect either with an iphone but I don't know.
Jon...
Hi Jon,
Hi Michel,
Thanks for continuing to help figure this out.
1. Yes, I can login to https://my.isy.iousing my email and password. It works great.
2. Yes, I have an active MobiLinc Connect account.
Hi Jon,
You cannot use email@URL. Please use a browser and go to https/my.isy.io ... you will be prompted to login. Please try logging in and let me know if that works.
Hi dwessels, thank you. Please send your UUID to support@universal-devices.com.
Yes I can log in that way.
Jon...
Hi Jon,
Ok, now please do let me know:
1. Do you see a green icon next to your ISY in the portal?
2. Admin Console | Configuration | Portals, what is the name of the portal (title around the Registered/OnLine)?
3. If possible, please attach a screenshot of MobiLinc configuration settings
If all else fails, we'll do a remote session to figure out the root cause.
Hi Jon,
1. Do you see a green icon next to your ISY in the portal? <-- Yes, mouse over reads "Online Since etc.,"
2. Admin Console | Configuration | Portals, what is the name of the portal (title around the Registered/OnLine)?<--- (First Name Initial)(Last Name)
3.)  If possible, please attach a screenshot of MobiLinc configuration settings
I've pm'd images for clarity :)
Jon...
