Aeotec color changing LED bulbs
I got two Aeotec color changing LED bulbs. Now it is my understanding that using ISY, I will not be able to change the colors. Is that correct? If yes, then do we know when this capability will be available in ISY?
The second issue is that each of these LED bulbs appear as a dimmer switch. I can control the light intensity percentage just fine. When I create a scene and add these bulbs to the scene, they appear as a temperature controller in programming. So, if I want to write a program to dim the scene to 5%, I cannot because in the drop down box, all I see is temperature settings. What am I doing wrong?
Arun
  • 9 months later...
Any update on this thread?  are the colors support yet ?
Hi wxmike,
You would need to install ISY v5.0.4 to access the color capabilities of the LED bulb.  Please be aware that the v5.0.4. firmware is still Alpha level code, and the follow on build 5.0.5 will also be Alpha.
Here's another thread discussing it ...
http://forum.universal-devices.com/topic/19662-aeon-labs-aeotec-z-wave-led-light-bulb-gen5/?hl=%2Bled+%2Bbulb
