Win10 on Raspberry 2
No idea.
Mono is not a hack. It is an open source implementation of .Net Framework for linux.
It is no more a hack than .Net itself.
Edited by io_guy
Ooh - I hadn't thought of that. Microsoft has an Iot build of Win10 that targets the rpi - specifically for running .net code.
Yeah, I was just reading a bit about it.  Sounds interesting and might tie in to my Windows PC world easier than Linux.  I will definitely keep this on the radar.  Might pick up an extra micro SD card to make a Windows image to test out.
  • 3 weeks later...
This may be a bit off base, but I didn't find a win10 only thread.
Does the latest, not Beta, release work with win10?  The print is tiny.
The font size is addressed in 4.4.1 as a feature in the admin console, but I believe 4.4.1 is still beta.
The other alternative is use this method. The directions were written for the touch screen Surface tablet, so you'll need to "right click" instead, where it says to "press and hold"
Paul
Edited by paulbates
Clicking "this method" doesn't bring me where I need to be.  Am I missing something?  Thanks.  BTW, it is a Surface Pro 4 with a keyboard.
I just installed v4.4.1 on my Surface 3 Pro and being able to change the font size was a big improvement. I didn't try out all screens, as I ran out of time, but it was better.
DC
I've gone through two Surface Pro's in the past few days and I have just finished installing a Dell XPS15. They all have had the mini print issue since the native resolution is +/- 3400 x ????. The aspect ratio on the Surface is 3/2; Dell, 16/9; monitor 16/9.
When I run the program on the connected monitor at a reduced resolution of +/- 1900 x ????, the size is fine.
Edited by haroldunger
No idea.
Spent a little time trying - seems one would need to install Mono as well in win10 to run an exe
However, I believe you can simply recompile you source and the development tool should generate the app needed (which should be easy to install)
Any chance you would be up to try it - if you develop in VB, it should be supported as far as I understand
It seems like a nice development platform
Tool a look, not going to happen. It's more than just a compile, the app needs to be changed to a UWP, which is not supported by standard Framework or mono.
Short answer, I won't be supporting it.
Maybe when .Net core comes along we might have some success (assuming W10 IOT supports it).
Edited by io_guy
