Echo/ISY skill setup problem
curmudgeon
In trying to send ISY commands via Echo,  I keep getting message from echo "ISY access is pending approval in admin console".
So far can't find how to grant this approval in admin console.   Help and direction, please?
Gary
Gary
Go to Manage Modules... Help > Manage Modules in the UI
Sorry, I can't read
Jon...
Edited by jerlands
Gary,
Have you installed to portal successfully?
Have you enable the ISY skill?
User error:  Echo show it had linked to ISY  BUT I had not bought an ISY portal.  thought my existing portal for MobiLinc Pro would work with Echo.
OK,  so bought portal, installed it, I had already created a portal ID with UUID and log in.
But now, when I go to configuration in the Admin console, there is NO portal tab under configuration!   Huh?
Have rebooted ISY and rebooted Admin console - but no portal tab.    Help, suggestions
What firmware and UI version are installed?  (Help > About in UI)
To add image to post click More Reply Options next to Post
Jon...
After purchasing the portal you should have gotten an email to register it. It needs to know which ISY to access.
Edited by stusviews
Posted same problem in another forum - the answer was that my UI was out of date.  Cleared java cache and reinstalled - portal tab appeared and I was able to give permission to communicate with the portal.  Not much luck yet getting devices to respond, but working on it.
  • 5 weeks later...
I seem to be having the same problem but my portal UI is not out of date. My portal shows "Offline" and I when I try to connect from the my.isy.io page it tells me it pending approval by owner, but I'm seeing no approval request.
The Admin approval request is in the Java Admin Console - not the ISY Portal Console.
What version does it show in 'Help' 'About'?
      377k
