Venstar - 0.2.7 HVAC State not recognized
Hi io_guy
I upgraded to 0.2.7 including the new profile. Everything appears to work except for HVAC state, in two programs like this.
HVAC Cycle FR Fan - [ID 002F][Parent 0017]
        'HVAC / Family Room' Heat/Cool State is Idle
    And 'HVAC / Attic-Damper Control' Status is Off
    And 'Kitchen / Doorwall Sensor-Opened' Status is Off
    And From     2:30:00AM
        To      10:30:00PM (same day)
The program used to execute regularly before the upgrade. Now, it won't run.
I rebooted nodelink and ISY. Because there are new options in the drop down, I changed to one of the other options and then reset it to Idle, and saved the program again, no luck. Nothing in the error log.
If I run the if, the icon turns red for several seconds and back to not running. I attached the log file for today. It's long. I cleared it down to the upgraded
Paul
logfile_2016-01-05.txt
Do you see the state changing in the main stat view in the admin console?
I don't see any issues in the log.  My guess is the ISY program is still using the old state reference that no longer exists.
Try changing the program state line to a completely different variable, saving, and then recreating.
That's a bit of a nasty ISY bug.  I'll send a note to the UDI guys about that - the program should indicate the broken reference somehow.
As noted in another thread I only show numeric values for Heat/Cool state.
Was ISY supposed to have something replaced to upgrade to 0.2.7?
EDIT: Uploading new profile file fixed the text again. Thanks.
Perhaps the link to that file could be included in the forum post with the docs. I did find the link in the docs but was looking for it in the post :)
