Best way to log events?
What is the best way to create a log file? For instance, if I want to know when a motion detector dawn/dusk sensor trips over the course of a week how would I create that log file?  I realize that I could just send an email, but that seems a little messy especially if it triggers very frequently.
thanks
thanks
ISY does have a log file you could download and run a filter on the output to isolate the events.
Depending on how many events you want to  keep in a log you can dedicate variables for each occurrence in ISY variables. I wouldn't try this with more than about a 10-15 events log, though.
I count every MS trigger per day in my ISY. 10 MS units. Did you need actual times or just a count?
Yeah, it would be nice to have a timestamp.
Unfortunately I don't have the network module.
Yeah, you'll need that to utilize that built in function.
Otherwise you can send emails and write an email parser, but I suspect the network module will be much better for your need, and it will open up all kinds of additional capability to you.
