An independent Event Viewer Window
C Martin
As of this point I use the event viewer to watch activities like everyone else.
Is it possible to have an event viewer that has its own window that can stay up independently from the main window?
Ideally if at all possible - an event viewer that doesn't need the ISY window at all. It can run in its own thread but watch the 99i's activities by itself as its own executable.
Hello C Martin,
If you are a Java developer or know someone who is, then you can make one in a day using our JSDK library + we'll even give you the UI code you need to build one.
Otherwise, this is going to go to the very bottom of our requirements/bugs.
Interesting and intriguing idea.
Unfortunately I have too much on my plate for now.
But I will consider this for a future time.
Clarence
