Fan Speed - One Button
I would like to use one button on a SwitchLinc to control a FanLinc's speeds.  My thoughts are this:
Pressing the button turns the fan on low, and beeps the SwitchLinc once, it also sets a five second countdown.
Pressing the button again within this five second countdown cycles through Medium (2 beeps), High (3 Beeps) Off.  Each button press resets the countdown timer to five seconds.
If the button is pressed after the five second countdown, it sets the fan to off.
I've been doing some searches but am still scratching my head.  Can anyone give me some pointers?
I don't have a fanlinc but I imagine you could do this with a couple variables and 4 programs or so...
if control switchlinc is switched on then "variable 1" +=1, "variable 2" =1, wait 5 second, "variable 2"=0 <<-- 1st program
if "variable 1"=1 and "variable 2"=1 then set fanlinc low, beep 90 <<-- 2nd program
if "variable 1"=2 and "variable 2"=1 then set fanlinc medium, beep 180 <<-- 3rd program
if "variable 1"=3 and "variable 2"=1 then set fanlinc high, beep 250 <<-- 4th program
if control swichlinc is switched on and variable 2=0 then fanlinc off <<-- 5th program
something like that...
Jon...
I have 4 programs for each fan I do this with.
If fan off and KPL a control on then set fan hi
If fan hi and KPL a control on then set fan med
Based entirely on the suggestions provided by jerlands and bambamf16. Thanks to you both.
Four scenes. Only the first two devices are of concern, CR FanLinc-Motor (FanLinc Motor) and CR KPLH CR Fan (KPL button H).
Although the scenes appear alike, the speed setting is set at the beginning of each scene, for example
Four Programs:
CR Fan High
        Control 'CR / Devices / CR KPL LR Light / CR KPLH CR Fan' is switched On   <--the button
    And Status  'CR / Devices / CR FanLinc-Light 80 / CR FanLinc-Motor' is Off       <--the motor
        Set Scene 'CR / Scenes / CR Fan-High' On   <--the scene
CR Fan Medium
    And Status  'CR / Devices / CR FanLinc-Light 80 / CR FanLinc-Motor' is High
        Set Scene 'CR / Scenes / CR Fan-Medium' On
CR Fan Low
    And Status  'CR / Devices / CR FanLinc-Light 80 / CR FanLinc-Motor' is Med
        Set Scene 'CR / Scenes / CR Fan-Low' On
CR Fan Off
    And Status  'CR / Devices / CR FanLinc-Light 80 / CR FanLinc-Motor' is Low
        Set Scene 'CR / Scenes / CR Fan-Off' Off
The scenes serve to allow both other controllers and use of the Echo to change the speed. The programs allow cycling through high, medium, low and off using one button. I may add beeps later.
And thanks to BrianLee for the inspiration to begin with.
Another use for the BuzzLinc B)
I use one button to control the speed of my whole house fan (5 total speeds, another house has one with 7), a single button actually has a lot of great modes you can track. I set the keypad button to "on only" (or whatever it is called), to make things simple. Now you have long press on (fade up), fast on (double press) and on (normal press). Logically, I like single press being increase speed and double press being decrease speed. I use long press for a forced off, so you don't have to decrease speed until its off. I have a couple of programs that just watch this and increment or decrement a state variable.
One other thing I do is add fast on to directly turn the fan of from any level. Add as a second or condition to the off program.
