March 26, 20169 yr Is there list of compatible devices to work with ISY and the Z-wave module? I know some other systems do have the correct firmware to work with everything. Thanks!
March 26, 20169 yr Can you provide a link to any system that has the "correct firmware to work with everything?" More importantly, what specifically do you want to control?
March 26, 20169 yr Author I misspoke... For example, I have a Qolsys alarm panel that only works with a VERY limited number of devices. I want to know simply what devices do work with the ISY? Such as motion sensors, outlets plug in modules etc. Anything form Aeon labs? Edited March 26, 20169 yr by mfranzel
March 26, 20169 yr Multi-channel Z-Wave devices are not currently supported by the ISY, but that's being worked on.
March 27, 20169 yr Hi mfranzel, We don't have a list mainly because with the nature of Z-Wave, controllers implement generic functionality. Therefore the ISY supports many devices we have never tested. For example, the ISY should control almost any dimmer from any manufacturer even though we only tested with a couple of them (GE being one). If you have specific devices you would like to know about, we may be able to help. Additionally, through their own experiences, others on this forum may be able to tell you about how compatible they are with ISY.
November 6, 20169 yr Hi mfranzel, We don't have a list mainly because with the nature of Z-Wave, controllers implement generic functionality. Therefore the ISY supports many devices we have never tested. For example, the ISY should control almost any dimmer from any manufacturer even though we only tested with a couple of them (GE being one). If you have specific devices you would like to know about, we may be able to help. Additionally, through their own experiences, others on this forum may be able to tell you about how compatible they are with ISY. Is the FortrezZ Mimo and Mimo Lite suported?
November 7, 20169 yr Is the FortrezZ Mimo and Mimo Lite suported? Hi Keith, We haven't tested it, but this thread may help http://forum.universal-devices.com/topic/13768-z-wave-io-module/
March 4, 20188 yr On 3/26/2016 at 4:08 PM, stusviews said: Multi-channel Z-Wave devices are not currently supported by the ISY, but that's being worked on. Stu, would that be accomplished by a firmware update or an updated Z-Wave module, or has it been added since you posted this? When I replace my front door sometime this year, I'm going to upgrade to an ISY-994iZW, a Z-Wave deadbolt, and other devices.
March 5, 20188 yr AFAIK, multi-channel devices are supported by ISY v5. That requires a firmware update, but v5 is still in Alpha. There is currently no newer Z-Wave module.
March 5, 20188 yr On 11/6/2016 at 5:15 PM, KSchex said: Is the FortrezZ Mimo and Mimo Lite suported? I use two Mimo-lites to control my curtains. I have had these for several months and zero issues.
March 6, 20188 yr The MimoLite is not a multi-mode Z-Wave devices. I'm using them successfully with ISY v 4.6.2.
May 2, 20187 yr Hi somebody have try those sensor ? http://www.z-wave.com/shop-z-wave-smart-home-products/smart-sensors-fibaro-fibaro-z-wave-plus-motion-multi-sensor Thank you to tell me if it's compatible. Jeff
May 2, 20187 yr 3 minutes ago, lilyoyo1 said: I have a lot of them and they work perfectly with the ISY. I'm using 5.0.12 What do you mean by I'm using 5.0.12 ? The ISY Firmware ? I just upgrade and I thing is 4.6.2
May 2, 20187 yr 59 minutes ago, autoperformance said: What do you mean by I'm using 5.0.12 ? The ISY Firmware ? I just upgrade and I thing is 4.6.2 You are using the official "stable" release of ISY firmware. Many of are using v5.0.12 alpha, and most of us find it completely stable and much more advanced.
May 2, 20187 yr 4 hours ago, autoperformance said: Where do you find this firmware ? I confirm that I consider 5.0.12 very stable Edited May 2, 20187 yr by asbril
