April 2, 201610 yr As many others have noticed the Multisensor 6 temperature sensors start reporting in Celsius and soon after change to Fahrenheit. Based on the info available on the web it was a belief that US version is in F and AU/EU version is in C. That is the default case but as many of you know Canada is using the metric system for units of measurement and so we expect the Celsius to be the temperature unit. I've submitted a ticket with Aeotec Technical Support and today have received a following response: Unfortunately there is no setting on the Multisensor 6 itself, the temperature setting must be set via the gateway of your Multisensor 6, but at the moment, there is no method to do so yet in the ISY994i ZW to my knowledge, I will try to work with the developers further as I have done before. Hopefully in a later update we will be able to solve this. Cheers, Chris Cheng Field Application Engineer Aeon Labs This tells me that the temperature unit selection is possible via command set and I would like to request UDI to work with Chris at Aeon Labs and incorporate that option into the ISY. Oskar
April 3, 201610 yr Hi Oskar, Chris contacted us and we'll be sending them a Z-Wave packet from ISY this week. With kind regards, Michel
June 11, 201610 yr Hi, Is there an update on this subject? I have a multisensor 6 and for some reason it has started reporting temps in Celsius (was Fahrenheit). Thanks, David
June 13, 201610 yr Hi David, Yes, it should be fixed in 5.0.5 (our next alpha firmware release). With kind regards, Michel
August 14, 20169 yr Author Michel, I've updated the firmware version to 1.07 (https://aeotec.freshdesk.com/support/solutions/articles/6000036562-multisensor-6-firmware-update-6-17-2016-) and have noticed that Aeon has documented new parameters for that firmware version. One of them is for the temperature units. 64 (0x40) Set the default unit of the automatic temperature report in parameter 101- 103. 1 = Celsius. 2 = Fahrenheit. I have changed the parameter 64 to 1 (it was on 2) and now I can see in ISY the temperature being reported in Celsius. I am running ISY on v4.5.1. The Engineering Specs can be found at https://aeotec.freshdesk.com/helpdesk/attachments/6028954764 I didn't have a chance to go through the rest of the doc to see what other changes are new to 1.07. Oskar
August 18, 20169 yr Michel, I've updated the firmware version to 1.07 (https://aeotec.freshdesk.com/support/solutions/articles/6000036562-multisensor-6-firmware-update-6-17-2016-) and have noticed that Aeon has documented new parameters for that firmware version. One of them is for the temperature units. 64 (0x40) Set the default unit of the automatic temperature report in parameter 101- 103. 1 = Celsius. 2 = Fahrenheit. I have changed the parameter 64 to 1 (it was on 2) and now I can see in ISY the temperature being reported in Celsius. I am running ISY on v4.5.1. The Engineering Specs can be found at https://aeotec.freshdesk.com/helpdesk/attachments/6028954764 I didn't have a chance to go through the rest of the doc to see what other changes are new to 1.07. Oskar Hi, I just purchased one and it defaults to Celsius. I have another and it reports in Fahrenheit. I would like both to be in the same units. I will try Parameter 64. Also, are the firmware upgrade instructions the same in your link for the ISY? Any special requirements or how to's? How does one find the firmware version of the device? Thanks PhanTomiZ
August 18, 20169 yr Hi, I just purchased one and it defaults to Celsius. I have another and it reports in Fahrenheit. I would like both to be in the same units. I will try Parameter 64. Also, are the firmware upgrade instructions the same in your link for the ISY? Any special requirements or how to's? How does one find the firmware version of the device? Thanks PhanTomiZ Hi PhanTomiZ, Using parameter 64 should work fine to get the desired units. Unfortunately, you cannot currently upgrade the firmware in your Z-Wave devices through the ISY, you will have to use some other method such as attaching it to your PC https://aeotec.freshdesk.com/support/solutions/articles/6000036562-multisensor-6-firmware-update-6-17-2016-
August 18, 20169 yr Hi PhantomiZ, The instructions for upgrade are all in the forum posts for each revision. With kind regards, Michel
August 19, 20169 yr Sorry for the need to be spoon fed...I can't seem to find a procedure anywhere withing the forum posts. Tried attaching to PC, but it doesn't recognize the device. After reading the procedure on the Aeotec site, it says "MultiSensor 6's firmware can be upgraded using Z-Stick from Aeotec and Microsoft Windows." Since I don't have a z-stick, I can't do the firmware upgrade. What am I missing? Thanks PhanTomiZ
August 19, 20169 yr Sorry for the need to be spoon fed...I can't seem to find a procedure anywhere withing the forum posts. Tried attaching to PC, but it doesn't recognize the device. After reading the procedure on the Aeotec site, it says "MultiSensor 6's firmware can be upgraded using Z-Stick from Aeotec and Microsoft Windows." Since I don't have a z-stick, I can't do the firmware upgrade. What am I missing? Thanks PhanTomiZ Hi PhanTomiZ, The procedure for upgrading the Aeon multisensor 6 using a PC is defined by Aeotec, so you may want to contact the support people at Aeotec directly ( https://aeotec.freshdesk.com/support/home ). As you mentioned, it does appear that you need a z-stick to do the firmware upgrade from your PC.
