Reduction In Number Of Programs?
I have 4 hidden door sensors and 1 triggerlinc to monitor our doors.
Each device has these 2 programs:
If open, notify with custom message identifying the door
If low battery, notify with custom message identifying the door
This a total of 10 programs.
Is there a way to program this setup to reduce the number of programs. I am assuming there might be a way with variables, but I have never used this asset and don’t know where to begin.
I have the same situation with 9 leak sensors so this is an area ripe for improvement, if possible.
Do you need to know every time a door is opened? If these are frequently used doors, all the notifications would drive me nuts.
Also consider your actions based on low battery. For example, I wait for my first smoke to start chirping, then replace the 9v batteries in all the smokes, since I know the others will chirp soon.
Nothing is jumping out at me as far as ideas to reduce number of programs. My only thoughts are to put all these into a program folder for organizational purposes only.
Reporting is controlled by a program that is enabled 5 minutes after a KPL button is pressed allowing us to leave the house w/o triggering a notification. We use MobiLinc to turn off reporting remotely if need be. Thus we only get notifications when we want them.
I have done that.
You can combine all your door sensors into a program using 'OR' for each sensor to trigger the program. If any of them open send a custom message using a substitution variable ${sys.node.#.name} to identify which device caused the trigger. You can do the same for a low battery message.
So 2 programs.
Edited by andyf0
Substitution variables. Not something I have ever used or needed, but I may try one out. I understand the "#" represents the address of the device that causes a program to run, correct?
Thanks for the tip!
  • 4 weeks later...
Andy, I am obviously doing something wrong. Would you be so kind as to draft example programs to handle two devices: House (37.D9.45 and Garage (38.D10.46)?
So 2 programs.
