April 17, 201610 yr I have a Ceiling Fan & Light that is currently controlled with a regular (non-ZWave) fan/light switch. I would like to replace it with ZWave or Insteon. The GE 12730 Z-Wave Smart Fan Control does not control the light and I have no space to add another ZWave light switch in the same box. How can I resolve this ? Any advise is welcome !!!
April 17, 201610 yr I use insteon. There is a fanlinc that goes in the fan canopy that controls the light and fan (three speeds). At the wall location, I use an insteon keypadlinc that sends commands to the fanlinc.
April 17, 201610 yr The Fanlinc works really well, I have 3, but the fanlinc has not fit in ANY of the fan canopies. I have had to install a triple box inline to hold the fanlinc
April 17, 201610 yr The Fanlinc works really well, I have 3, but the fanlinc has not fit in ANY of the fan canopies. I have had to install a triple box inline to hold the fanlinc Only one of our six fans has a canopy too small for the FanLinc. But you are correct. a 3-gang wall box is the alternative. Keep in mind that the box has to be accessible according to the code. An attic or crawl space is considered accessible.
May 15, 201610 yr Author I think that my solution will be to put 3 Everspring AN145 Z-Wave Screw-In Lamp Sockets in the fan lights. I would then replace the NON ZWave fan/light switch with a ZWave fan switch and control the fan lights through the Administrative Console and with a Multi-channel scene controller, once ISY 5.X works well with multi-channel. Edited May 15, 201610 yr by asbril
May 15, 201610 yr I'm ready to remove the GE Smart Fan Control. It's simply too time taking for easy control. Hold and press and observe. The LED blinks for 10 seconds every 2 seconds, every 1 second or every 1/2 second for low, medium or high speed, respectively. One tap on a Keypad button sets the speed using a FanLinc and the specified speed button LED turns on. And both the light and fan control are in one place. A Mini Remote can also be used to control everything.
June 12, 20169 yr Thank you for the thread, since my entire living room and dining room are bare trusses at the moment, was dropping fan box into the new cathedral ceiling and remarking how small it was in that box.One could certainly use a micro-switch in there for the light itself, but no way a fanlinc will fit in there.That left me thinking about running a second set of wires into the fan box itself so I could have a 14-3 and a 14-2 in there to get to the lights from a fanlinc installed in the attic.It's operating range says "indoor", anyone having issues with the fanlinc in the attic where it get's quite hot in the summer? Alan
June 13, 20169 yr I'm ready to remove the GE Smart Fan Control. It's simply too time taking for easy control. Hold and press and observe. The LED blinks for 10 seconds every 2 seconds, every 1 second or every 1/2 second for low, medium or high speed, respectively. One tap on a Keypad button sets the speed using a FanLinc and the specified speed button LED turns on. And both the light and fan control are in one place. A Mini Remote can also be used to control everything. Have you found another alternative that isn't a FanLinc? I too do not like the fact that you have to press and hold the GE switch. The fact I can control it with the Echo is the only thing saving it from the garbage can. As soon as I find a decent in-wall alternative, it will be replaced.
July 30, 20169 yr hmmm. The GE fan control doesn't control the lights (if needing a single fan/light controller). I'm not sure you can compare the two either, GE vs Insteon. From what I've been reading, Insteon is their own product and you need an Insteon hub to be able to make it work. Is this not the case? The GE switch is pure zwave and will work with any zwave controller. This should be pointed out to people reading this article thinking that FanLinc is the solution to the problem. If already in a zwave universe (or DIY like me), this is not a solution.
July 30, 20169 yr The Insteon FanLinc needs only a linked Insteon device to make it work. The links can be created by pushing buttons. Nothing else is required. This is true for all Insteon devices (RF devices need at least on wired dual-band device).
July 30, 20169 yr If someone is reading this on here, I would assume they have an ISY which works with insteon as well. While Insteon would not be compatible with zwave only controllers, you could still manually link the ranking to another insteon device such as a keypad for insteon control
July 30, 20169 yr Will add that the fan we bought turned out to be NOT controllable with the Fanlinc and that is $80 down the drain. Must have a secret DC motor running it, no posts to that effect on any online site i could find, not mentioned in the manual, and an email to Smarthome was answered with the boilerplate BS from low level tech support.Wasted a couple of hours trying to make it work, with it inline to the motor, no go, bypass it and the motor worked fine.I was able to fit the fanlinc into the "canopy" openeng that you slide the down rod into, and put part of it there and part into the junction box the fan hung from, however since it would not control the motor, it's not in there anymore. Perhaps on the black friday sale I will buy 2 micro modules, one for the lights and one for the fan motor and see if they will do the job. The micro module will have to be a relay style. Don't think I can take 1/2 of my 2 wire setup from before the remodel and make that work.
July 30, 20169 yr Which specific fan/light? I'm not sure what "1/2 of my 2 wire setup means?" Edited July 30, 20169 yr by stusviews
July 30, 20169 yr Will add that the fan we bought turned out to be NOT controllable with the Fanlinc and that is $80 down the drain. Must have a secret DC motor running it, no posts to that effect on any online site i could find, not mentioned in the manual, and an email to Smarthome was answered with the boilerplate BS from low level tech support. Wasted a couple of hours trying to make it work, with it inline to the motor, no go, bypass it and the motor worked fine. I was able to fit the fanlinc into the "canopy" openeng that you slide the down rod into, and put part of it there and part into the junction box the fan hung from, however since it would not control the motor, it's not in there anymore. Perhaps on the black friday sale I will buy 2 micro modules, one for the lights and one for the fan motor and see if they will do the job. The micro module will have to be a relay style. Don't think I can take 1/2 of my 2 wire setup from before the remodel and make that work. Not controllable? What does the fan do?
July 30, 20169 yr Some of the modern fans now use DC controllers and motors. That the FanLinc will not work with. If the fan i question is using a DC controller with motor setup. I have seen no ways reported to control them with a Fanlinc. Just failure to control reports.
July 30, 20169 yr No current HA device can control a DC motor unless it's low voltage (<30VDC) and only On/Off is needed.
July 31, 20169 yr No current HA device can control a DC motor ... What if the motor is from one of the 50 states?
July 31, 20169 yr What if the motor is from one of the 50 states?Hehehehe. It took a few seconds but once it hit me I almost chocked. Good one, Larry. Best regards, Gary Funk
