RainMachine - Node server only adds even numbered zones
I just installed and configured NodeLink this morning (Mac OS X El Capitan), and it seems to work, however only even numbered zones are visible in the ISY.
I have 12 total zones, with 2 being inactive.  My RainMachine accommodates all 12 zones, but for whatever reason, the ISY only displays zones 02, 04, 06, 08, 10 and 12.
The NodeLink server apparently sees all 12 zones (the NodeLink device page indicates there are indeed 12 zones).  Attached is a screenshot of my ISY.  ISY firmware and UI are both at 5.0.4.
From the logs, I assume that there may be network issues that would cause this (404 errors), but I'm just guessing.  A clip of the log is below.  This isn't urgent as the RainMachine is operating normally, but I'd like to be able to more closely manage my irrigation as the hot weather approaches.
Thanks for your time.
Bumbershoot
2016-05-31 10:57:46 - Auto-Update: Checking for program update...
2016-05-31 10:57:46 - Auto-Update: No web update available
2016-05-31 10:57:47 - ISY: Variable irrigator-ST added to queue (Val: 0, QS: 1)
2016-05-31 10:57:48 - ISY: Variable irrigator-GV1 added to queue (Val: -1, QS: 2)
2016-05-31 10:57:48 - ISY: Variable irrigator_z1-ST added to queue (Val: 0, QS: 3)
2016-05-31 10:57:48 - ISY:  (ns/4/nodes/n004_irrigator/report/status/ST/0/25)
2016-05-31 10:57:48 - ISY: Variable irrigator_z2-ST added to queue (Val: 0, QS: 3)
2016-05-31 10:57:48 - ISY: Variable irrigator_z3-ST added to queue (Val: 0, QS: 4)
2016-05-31 10:57:48 - ISY: Variable irrigator_z4-ST added to queue (Val: 0, QS: 5)
2016-05-31 10:57:48 - ISY: Variable irrigator_z5-ST added to queue (Val: 0, QS: 6)
2016-05-31 10:57:48 - ISY: Variable irrigator_z6-ST added to queue (Val: 0, QS: 7)
2016-05-31 10:57:48 - ISY: Variable irrigator_z7-ST added to queue (Val: 0, QS: 8)
2016-05-31 10:57:48 - ISY: Variable irrigator_z8-ST added to queue (Val: 0, QS: 9)
2016-05-31 10:57:48 - ISY: Variable irrigator_z9-ST added to queue (Val: 0, QS: 10)
2016-05-31 10:57:48 - ISY: Variable irrigator_z10-ST added to queue (Val: 0, QS: 11)
2016-05-31 10:57:48 - ISY:  (ns/4/nodes/n004_irrigator/report/status/GV1/-1/25)
2016-05-31 10:57:48 - ISY: Variable irrigator_z11-ST added to queue (Val: 0, QS: 11)
2016-05-31 10:57:48 - ISY: Variable irrigator_z12-ST added to queue (Val: 0, QS: 12)
2016-05-31 10:57:48 - ISY Error: The remote server returned an error: (404) OK. (ns/4/nodes/n004_irrigator_z1/report/status/ST/0/25)
2016-05-31 10:57:48 - Web Request: /index.htm
2016-05-31 10:57:48 - Web Request: /general.css
2016-05-31 10:57:57 - Web Request: /irrigator.htm
2016-05-31 10:57:57 - Web Request: /general.css
2016-05-31 10:58:07 - Web Request: /isylink/nodes/n004_irrigator/query?requestId=61
2016-05-31 10:58:11 - ISY Error: The remote server returned an error: (404) OK. (ns/4/nodes/n004_irrigator/add/RainMachine?primary=n004_irrigator&name=RainMachine&nls=123R)
2016-05-31 10:58:11 - ISY:  (ns/4/nodes/n004_irrigator_z1/add/RainMachineZone?primary=n004_irrigator&name=Zone 01&nls=123RZ)
2016-05-31 10:58:13 - ISY Error: Error getting web response from the ISY (Error getting response stream (ReadDone2): ReceiveFailure)
2016-05-31 10:58:13 - ISY:  (ns/4/nodes/n004_irrigator_z3/add/RainMachineZone?primary=n004_irrigator&name=Zone 03&nls=123RZ)
2016-05-31 10:58:13 - ISY Error: The remote server returned an error: (404) OK. (ns/4/nodes/n004_irrigator_z4/add/RainMachineZone?primary=n004_irrigator&name=Zone 04&nls=123RZ)
2016-05-31 10:58:15 - ISY Error: Error getting web response from the ISY (Error getting response stream (ReadDone2): ReceiveFailure)
2016-05-31 10:58:15 - ISY Error: The remote server returned an error: (404) OK. (ns/4/nodes/n004_irrigator_z6/add/RainMachineZone?primary=n004_irrigator&name=Zone 06&nls=123RZ)
2016-05-31 10:58:17 - ISY Error: Error getting web response from the ISY (Error getting response stream (ReadDone2): ReceiveFailure)
2016-05-31 10:58:17 - ISY Error: The remote server returned an error: (404) OK. (ns/4/nodes/n004_irrigator_z8/add/RainMachineZone?primary=n004_irrigator&name=Zone 08&nls=123RZ)
2016-05-31 10:58:18 - ISY: Variable irrigator-GV1 added to queue (Val: 1, QS: 13)
2016-05-31 10:58:18 - ISY:  (ns/4/nodes/n004_irrigator_z9/add/RainMachineZone?primary=n004_irrigator&name=Zone 09&nls=123RZ)
2016-05-31 10:58:18 - ISY Error: Error getting web response from the ISY (Error getting response stream (ReadDone2): ReceiveFailure)
2016-05-31 10:58:18 - ISY:  (ns/4/nodes/n004_irrigator_z11/add/RainMachineZone?primary=n004_irrigator&name=Zone 11&nls=123RZ)
2016-05-31 10:58:18 - Web Request: /general.css
2016-05-31 10:58:18 - ISY:  (ns/4/nodes/n004_irrigator_z1/report/status/ST/0/25)
2016-05-31 10:58:19 - ISY:  (ns/4/nodes/n004_irrigator_z2/report/status/ST/0/25)
2016-05-31 10:58:19 - ISY:  (ns/4/nodes/n004_irrigator_z3/report/status/ST/0/25)
2016-05-31 10:58:19 - ISY:  (ns/4/nodes/n004_irrigator_z4/report/status/ST/0/25)
2016-05-31 10:58:19 - ISY Error: The remote server returned an error: (404) OK. (ns/4/nodes/n004_irrigator_z5/report/status/ST/0/25)
2016-05-31 10:58:48 - ISY: Variable irrigator-GV1 replaced in queue (Val: -1, QS: 9)
2016-05-31 10:58:49 - ISY Error: The remote server returned an error: (404) OK. (ns/4/nodes/n004_irrigator_z5/report/status/ST/0/25)
2016-05-31 10:59:18 - ISY: Variable irrigator-GV1 replaced in queue (Val: 1, QS: 9)
2016-05-31 10:59:20 - ISY Error: The remote server returned an error: (404) OK. (ns/4/nodes/n004_irrigator_z5/report/status/ST/0/25
Hit the add zones buttons a few more times until they all are visible in the ISY.
Thats "Node Servers | isylink | Add All Nodes"?  I've given that maybe a dozen tries, and nothing yet.  I could try adding an individual node if I understood the data the attached dialogue box was looking for.
Bumbershoot
No, you never do that. Follow the howto.
In NodeLink you use the install nodes button.
Thanks.  Success.  It took another reboot of the ISY, but all the zones are now present.
