Sunset time wrong Toronto ver.4.4.2
My sunset time is wrong... it was also wrong when set for Boston (now Toronto, same thing)
on 4.4.6
Should be 9:12pm, says 9pm, so things starting/stopping too early.
see attached screenshot...
on 4.4.6
Mine seems a little early also but if you check online sources you will find 9:00 for GTA is correct by most sources.
EDIT: I see you are not in Toronto. If you use the correct Lat/Long for OS you will get 9:12 PM
Hi,
I'm east of Toronto, Whitby.  I used the "locate me" which I believe finds my ISP which is in Oshawa.  I'm also showing 9:00:57 as today's sunset.  Never really paid any attention to whether it was correct or not.  I used the "locate me" because I couldn't get Whitby and I didn't think Toronto was an option or at least it may not have been an option when I installed my ISY.
I just changed my location to Toronto and as you'd expect, no change to sunset time.
I just checked your "location" being Owen Sound and you are 2 1/2 hours north west of me.  I believe it would correct your sunrise/sunset times if you use your Lat/Long position as larryllix says...
PhanTomiZ
THANKS to both of you!
I didn't realize I could manually set the latitude and longitude.
Set it, and now it is correct, as you stated.
AGAIN, THANKS!
Fred
