Thermostat erroneously returning 0 as status value
CompKing
I have a program which regularly (every 5 mins) queries the thermostat for its reported temperature. I have a program which monitors the value and if below a threshold it adjusts the set temperature. I have had this program running for approx 4 months in all the prior betas.
A symptom I have is occasionally the program is executed when the temperature reported is erroneously reported as "zero", which may be a default on bad comm's. As a "wireless device", perfect communication is likely not possible.
So far, I only have a capture of my log with the Temperature entries. I have turned on event viewer to see if I can capture level 2 comms when this happens.
The funny part is this only happened weekly previously. Now, it seems to happen multiple times in a single day.
Here is a log of the applicable portion.
THERMOSTAT Status Query░ Sat 01/03/2009 11:51:51 AM Program Log
THERMOSTAT Humidity 0.24 Sat 01/03/2009 11:52:04 AM System Log
THERMOSTAT Fan State On Sat 01/03/2009 11:55:59 AM Program Log
THERMOSTAT Status 26░ Sat 01/03/2009 11:56:10 AM System Log
THERMOSTAT Humidity 0.23 Sat 01/03/2009 11:56:22 AM System Log
THERMOSTAT Fan State Auto Sat 01/03/2009 11:56:25 AM Program Log
THERMOSTAT Humidity 0.24 Sat 01/03/2009 11:57:01 AM System Log
THERMOSTAT Status Query░ Sat 01/03/2009 11:57:09 AM Program Log
THERMOSTAT Status Query░ Sat 01/03/2009 12:03:31 PM Program Log
THERMOSTAT Status 27░ Sat 01/03/2009 12:03:33 PM System Log
THERMOSTAT Fan State On Sat 01/03/2009 12:04:10 PM Program Log
THERMOSTAT Status 0░ Sat 01/03/2009 12:04:44 PM System Log
THERMOSTAT Heat Setpoint 18░ Sat 01/03/2009 12:05:16 PM Program Log
THERMOSTAT Status 27░ Sat 01/03/2009 12:05:20 PM System Log
THERMOSTAT Setpoint 18░ Sat 01/03/2009 12:05:53 PM System Log
THERMOSTAT Thermostat Mode Heat Sat 01/03/2009 12:06:37 PM Program Log
THERMOSTAT Humidity 0.23 Sat 01/03/2009 12:07:20 PM System Log
Note the "Status 0".
Also note the number of entries in each "5 minute" time period varies. Some have 2 lines with values, some have 3 lines. Some show 'Query' and no results, and some are quite comprehensive.
Regardless of how good/poor my wireless traffic, I would argue that a zero value should not be assumed unless on poor data packets.
Regards
Geoff
I have captured the event using Event Viewer. I hope this helps.
The time of "status" being reported as "0" in the event log shows as 03:06:01 PM
The relevant areas of the log are:
2009/01/03 15:04:11 : [iNST-SRX ] 02 50 0A.3C.92 0C.A5.CB 41 13 01 LTOFFRR(01)
2009/01/03 15:04:12 : [iNST-ACK ] 02 62 0E.63.53 0F 6A 00 06 (00)
2009/01/03 15:04:20 : [iNST-ACK ] 02 62 0E.63.53 0F 6A 00 06 (00)
2009/01/03 15:04:21 : [iNST-SRX ] 02 50 0E.63.53 0C.A5.CB 27 6A 32 (32)
2009/01/03 15:04:21 : [iNST-ACK ] 02 62 0E.63.53 0F 6A 20 06 (20)
2009/01/03 15:04:30 : [iNST-ACK ] 02 62 0E.63.53 0F 6A 20 06 (20)
2009/01/03 15:04:39 : [iNST-ACK ] 02 62 0E.63.53 0F 6A 20 06 (20)
2009/01/03 15:04:40 : [iNST-SRX ] 02 50 0E.63.53 0C.A5.CB 27 6A 32 (32)
2009/01/03 15:04:41 : [iNST-ACK ] 02 62 0E.63.53 0F 6A 60 06 (60)
2009/01/03 15:04:49 : [iNST-ACK ] 02 62 0E.63.53 0F 6A 60 06 (60)
2009/01/03 15:04:50 : [iNST-SRX ] 02 50 0E.63.53 0C.A5.CB 23 6A 18 (18)
2009/01/03 15:04:50 : [iNST-ACK ] 02 62 0E.63.53 0F 6B 02 06 (02)
2009/01/03 15:04:59 : [iNST-ACK ] 02 62 0E.63.53 0F 6B 02 06 (02)
2009/01/03 15:04:59 : [iNST-SRX ] 02 50 0E.63.53 0C.A5.CB 27 6B 01 (01)
2009/01/03 15:04:59 : [ Time] 15:05:29 1(0)
2009/01/03 15:05:16 : [ Time] 15:05:46 1(0)
2009/01/03 15:05:18 : [iNST-ACK ] 02 62 00.00.21 CF 11 FF 06 LTONRR (FF)
2009/01/03 15:05:19 : [iNST-ACK ] 02 62 0E.63.53 0F 6B 07 06 (07)
2009/01/03 15:05:28 : [iNST-ACK ] 02 62 0E.63.53 0F 6B 07 06 (07)
2009/01/03 15:05:30 : [iNST-SRX ] 02 50 0E.63.53 0C.A5.CB 27 6B 07 (07)
2009/01/03 15:05:30 : [iNST-ACK ] 02 62 0E.63.53 0F 6A 00 06 (00)
2009/01/03 15:05:30 : [iNST-SRX ] 02 50 0E.63.53 0C.A5.CB 27 6A 00 (00)
2009/01/03 15:05:31 : [iNST-ACK ] 02 62 0E.63.53 0F 6A 20 06 (20)
2009/01/03 15:05:39 : [iNST-ACK ] 02 62 0E.63.53 0F 6A 20 06 (20)
2009/01/03 15:05:40 : [iNST-SRX ] 02 50 0E.63.53 0C.A5.CB 27 6A 32 (32)
2009/01/03 15:05:40 : [iNST-ACK ] 02 62 0E.63.53 0F 6A 60 06 (60)
2009/01/03 15:05:49 : [iNST-ACK ] 02 62 0E.63.53 0F 6A 60 06 (60)
2009/01/03 15:05:50 : [iNST-SRX ] 02 50 0E.63.53 0C.A5.CB 27 6A 18 (18)
2009/01/03 15:05:50 : [iNST-ACK ] 02 62 0E.63.53 0F 6B 02 06 (02)
2009/01/03 15:05:59 : [iNST-ACK ] 02 62 0E.63.53 0F 6B 02 06 (02)
2009/01/03 15:06:08 : [iNST-ACK ] 02 62 0E.63.53 0F 6B 02 06 (02)
2009/01/03 15:06:09 : [iNST-SRX ] 02 50 0E.63.53 0C.A5.CB 27 6B 01 (01)
2009/01/03 15:06:09 : [ A AD 16 4] ST 255
2009/01/03 15:06:09 : [ 9 91 5D 5] ST 255
2009/01/03 15:06:09 : [ B E3 76 1] ST 255
2009/01/03 15:06:09 : [ E 63 53 1] ST 0
2009/01/03 15:06:09 : [iNST-ACK ] 02 62 00.00.24 CF 11 FF 06 LTONRR (FF)
2009/01/03 15:06:10 : [iNST-ACK ] 02 62 0E.63.53 0F 6D 24 06 (24)
2009/01/03 15:06:12 : [iNST-SRX ] 02 50 0E.63.53 0C.A5.CB 27 6D 24 (24)
2009/01/03 15:06:12 : [iNST-ACK ] 02 62 0E.63.53 0F 6A 00 06 (00)
2009/01/03 15:06:12 : [iNST-SRX ] 02 50 0E.63.53 0C.A5.CB 27 6A 00 (00)
2009/01/03 15:06:12 : [iNST-ACK ] 02 62 0E.63.53 0F 6A 20 06 (20)
2009/01/03 15:06:13 : [iNST-SRX ] 02 50 0E.63.53 0C.A5.CB 27 6A 24 (24)
2009/01/03 15:06:13 : [iNST-ACK ] 02 62 0E.63.53 0F 6A 60 06 (60)
2009/01/03 15:06:22 : [iNST-ACK ] 02 62 0E.63.53 0F 6A 60 06 (60)
2009/01/03 15:06:23 : [iNST-SRX ] 02 50 0E.63.53 0C.A5.CB 27 6A 19 (19)
2009/01/03 15:06:24 : [iNST-ACK ] 02 62 0E.63.53 0F 6B 02 06 (02)
2009/01/03 15:06:25 : [iNST-SRX ] 02 50 0E.63.53 0C.A5.CB 27 6B 01 (01)
2009/01/03 15:06:26 : [iNST-ACK ] 02 62 0E.63.53 0F 6B 04 06 (04)
2009/01/03 15:06:35 : [iNST-ACK ] 02 62 0E.63.53 0F 6B 04 06 (04)
2009/01/03 15:06:35 : [iNST-SRX ] 02 50 0E.63.53 0C.A5.CB 27 6B 04 (04)
2009/01/03 15:06:35 : [iNST-ACK ] 02 62 0E.63.53 0F 6A 00 06 (00)
2009/01/03 15:06:44 : [iNST-ACK ] 02 62 0E.63.53 0F 6A 00 06 (00)
2009/01/03 15:06:46 : [iNST-SRX ] 02 50 0E.63.53 0C.A5.CB 23 6A 32 (32)
2009/01/03 15:06:46 : [iNST-ACK ] 02 62 0E.63.53 0F 6A 20 06 (20)
2009/01/03 15:06:55 : [iNST-ACK ] 02 62 0E.63.53 0F 6A 20 06 (20)
2009/01/03 15:06:56 : [iNST-SRX ] 02 50 0E.63.53 0C.A5.CB 27 6A 24 (24)
2009/01/03 15:06:56 : [iNST-ACK ] 02 62 0E.63.53 0F 6A 60 06 (60)
2009/01/03 15:07:05 : [iNST-ACK ] 02 62 0E.63.53 0F 6A 60 06 (60)
2009/01/03 15:07:05 : [iNST-SRX ] 02 50 0E.63.53 0C.A5.CB 27 6A 19 (19)
2009/01/03 15:07:05 : [iNST-ACK ] 02 62 0E.63.53 0F 6B 02 06 (02)
2009/01/03 15:07:14 : [iNST-ACK ] 02 62 0E.63.53 0F 6B 02 06 (02)
2009/01/03 15:07:15 : [iNST-SRX ] 02 50 0E.63.53 0C.A5.CB 27 6B 01 (01)
2009/01/03 15:07:15 : [ A AA F5 8] ST 255
2009/01/03 15:07:15 : [ A AE 44 5] ST 255
2009/01/03 15:07:15 : [ 9 91 5D 4] ST 255
2009/01/03 15:07:15 : [ E 63 53 1] CLISP 36
2009/01/03 15:07:16 : [ E 63 53 1] CLIHUM 25
2009/01/03 15:07:16 : [iNST-ACK ] 02 62 00.00.24 CF 11 FF 06 LTONRR (FF)
2009/01/03 15:07:16 : [ E 63 53 1] ST 50
Hello CompKing,
This has been fixed in 2.6.14 ... just for reassurance, this is a LOG bug where instead of saying Query, the log is just showing 0. In short, those entries are the query REQUEST and not the response.
Thank you for the prompt response. So it sounds to me even though there is a bug in the log, the "fix" will also impact the erroneous impact on my programs which rely on the returned value of the thermostat?
Hello again,
The bug should not impact your programs right now. If you see 0 for the status of your thermostats, then please go to Help->About and let me know the version number.
Hello again,
I confirm this DOES impact my programs in 2.6.13 (as confirmed with Help -> About)
My Product is ISY99/IR Pro (1050)
The zero value both triggers a program, shows up in Admin Console device status, and under regular device status on the web interface.
Keep in mind I am running in Celcius, not Farenheit.
It is intermittent, and a subsequent query of the thermostat will typically clear up the zero value to the proper room temperature.
Hello CompKing,
Thanks so very much for the update. I shall have it checked out again though I have not been able to reproduce it under 2.6.13. If another query resolves this, then perhaps we can also move the AccessPoint close to the thermostat to see if it helps the issue.
Hello again,
Hello CompKing,
By moving the AP from 40ft to 4ft away from the thermostat module, I have not detected a zero value for the returned value since. It is unfortunate that noise would be interpreted as a zero instead of an invalid result (and thus ignored). I am assuming that noise caused the issue since it did resolve itself, but even 40 ft away shouldn't be a problem (same floor, neighboring room, mostly open space between)
Hello CompKing,
I totally agree with you. The main issue is that we have nothing to do with the error detection/correction (the PLM is doing all that) and, as such, we can only report back what the PLM sends back to us.
Would you be kind enough to do one more test? Would you move your Access Point back to where it was originally, reboot your thermostat, and retry?
Hello CompKing,
Hello CompKing,
Hello CompKing,
I haven't been ignoring your response, I have been on vacation. I do note that in the 4ft location that I still do occasionally get 0 thermostat values in my programs, though not as often (once ever 40 hours or so). I can try moving it back to the original location (when I have a sec), and see if the problem worsens. Regardless, even at 4 ft I still get the invalid/zero values.
Regards
HI CompKing,
We are going to have 2.6.14 released in a few minutes. So, perhaps, it would be best if you tried your experiments with the latest release?
Hello CompKing,
Hello CompKing,
Regards
HI CompKing,
So far, so good. Been almost 24 hours, and no zero's noted. Fingers crossed
Hello CompKing,
HI CompKing,
      37.5k
      375.5k
