Keypad and fanlinc confusion
Ok so I installed a ceiling fan this past weekend and I put in a fanlinc and a keypad to control it.
This is a keypad with the top and bottom two bridged/6button if it matters.
So I tried to do all the crosslinking and it works, but it works differently than an 8 button keypad and fanlinc I have in another room.
This new one is set to toggle for all buttons and I have button A set to low fan, B to med fan and C to high fan.  The thing is that when A is already pressed and the fan is running on low pressing B will change to med fan speed, but button A is still lit. So now the speed is med , but both buttons are lit.
The other keypad and fanlinc I have doesn't do this. If A is pushed and then B is pushed then the speed goes up and the A button light goes out.
I have poured over the admin console trying to figure it out , but everything looks the same except the different versions.
Any ideas what I should look into?
I am not sure how others accomplish this, but I put all of the buttons in a scene for each state of the fan and set the appropriate levels for each button and fan motor depending on the button press.
There is either a Scene being used by the 8 button which sets the On Level of the other KPL buttons to 0% On (Off), or there is a Program that is turning Off the other buttons.  KPL does not automatically turn Off other buttons.
I'll have to look harder I guess.
I do have a scene for each button and each speed and I'm 99.9% sure there are no programs turning off the buttons on the 8 button keypad.
Will report back when home and can check.
Thanks for the replies.
It does if you group the buttons.
Best regards,
Gary Funk
Check the scene for the speed B represents. Look at the sub node under that scene for button B. In that make sure the "on level" for A is 0%.
Buttons Grouping should not be used with ISY.
I've seen that warning forever. I've grouped all 11 of my FanLink KPLs and I've never seen a problem.
Best regards,
Gary Funk
The problem occurs if and when you make changes, most especially a reset. Read the warning. You may also encounter difficulties if you need to replace a device.
I have used groupings in the past, as well, but prefer scenes so I do not use them now.  Never saw a problem, but never made changes or replaced such a device.
  Be sure to take advantage of the tools.  Select the device in question and it will show the scenes in which it is a part.  From the programs list, there is a "find and replace" option that is very helpful for finding where certain devices are contained in a program.
I hadn't heard anything about the grouping. That is how my 8 key keypad is and I did the same to the 6 key.
Now I have ungrouped and done the scene the way james and apnar recommended and all is well so far.
The only other thing I wondered was can you add a fast off to turn both fan and light off to a scene or does it need to be a program?
I couldn't figure out how if you can do it in a scene.
Thanks for all the helpful replies.
A scene will respond to off or fast off, but a button or paddle can control only one scene. If you want to a button or paddle that's already a controller for a scene, then you'll need to use a program. The quickest response will occur if the program controls a scene rather than two devices. Create a scene where the trigger is a button or paddle fast off (If) and Then turns off the scene that has only the light and motor as responders.
Edited by stusviews
