Random Noise appearing in Log
My system today after a reboot is now showing continuous entries in the event log of random activity, and "system busy" status.
There is no IR source present which would cause this. Nothing new on the device front.
The only change I had made was to activate the WB module.
Ever seen this before?
2009/01/07 18:40:04 : [ IR] 0292 Press
2009/01/07 18:40:04 : [ A 8A B0 1] OL 76
2009/01/07 18:40:04 : [ IR] 0154 Press
2009/01/07 18:40:05 : [ IR] 028A Press
2009/01/07 18:40:05 : [ IR] 02CA Press
2009/01/07 18:40:05 : [ IR] 0255 Press
2009/01/07 18:40:05 : [ A 8A B0 1] RR 26
2009/01/07 18:40:05 : [ IR] 0295 Press
2009/01/07 18:40:05 : [ 6 D5 D8 1] ST 0
2009/01/07 18:40:06 : [ IR] 0095 Press
2009/01/07 18:40:07 : [ IR] 02D5 Press
2009/01/07 18:40:07 : [ IR] 0125 Press
2009/01/07 18:40:07 : [ IR] 01D2 Press
2009/01/07 18:40:08 : [ IR] 0156 Press
2009/01/07 18:40:08 : [ IR] 0155 Press
2009/01/07 18:40:08 : [ IR] 0145 Press
2009/01/07 18:40:09 : [ 6 D5 D8 1] OL 102
2009/01/07 18:40:09 : [ IR] 0155 Press
2009/01/07 18:40:09 : [ IR] 02D5 Press
2009/01/07 18:40:09 : [ 6 D5 D8 1] RR 0
2009/01/07 18:40:10 : [ IR] 02AD Press
2009/01/07 18:40:10 : [ IR] 0154 Press
2009/01/07 18:40:10 : [ IR] 0145 Press
2009/01/07 18:40:11 : [ A AD 1 1] ST 0
2009/01/07 18:40:12 : [ IR] 022A Press
2009/01/07 18:40:12 : [ IR] 02A5 Press
bright sunlight and plasma or LCD TV's can all cause IR interference, is yyur ISY reasonably isolated from all?
Funny enough my Plasma wasn't ever on when I noticed this. In the end I did up doing a factory restore, and relocated the ISY-99. All seems well.
After spending a little more time to isolate the problem in the original location, I found out it was my Roomba iRobot docking station which was sending IR signals to the vacuum to tell it to come home. Guess it was lonely and had to talk to my ISY since my vacuum wasn't listening.
lol. Perhaps too many gadgets.
CompKing!
I just had to post because you just made my day .... after a LOOOONG day, I needed this laugh! LOL.
