X10 Finally clause
Is the finally clause meant to work with x10 as in the following example? Is something else required?
       Receive X10 House Code 'L'  Unit Code '7' Command '3 - On'
       Set 'Office - Test LL' On
Finally
       Wait  10 seconds
       Set 'Office - Test LL' Off
GPG,
I think for what you want accomplish, you can simply put the 'Wait' and 'Set Office - Test LL' statements right below the first statement in your Then clause.
Finally
       Wait  10 seconds
I just used that as an example. The lamp remains on. Why doesn't the finally clause execute and turn the lamp off?
George
The 'Finally' clause is run when the 'If' is no longer true.
This description pertains to Controls in conditions as well (eg. Fast On/Fast Off etc.)
In this case, you received an X10 L.7.3 message, and thus the light goes on. It is not possible to make this 'If' false, therefore the 'Finally' won't run.
Finally
There are two solutions
First Solution
The simplest is to just add another program and not use 'Finally'
Program1:
Finally
Program2:
       Receive X10 House Code 'L'  Unit Code '7' Command '11 - Off'
Finally
Second Solution
Include the 'Off' button in the 'If', thus allowing the 'If' condition to change:
        Or Receive X10 House Code 'L'  Unit Code '7' Command '11 - Off'
   And Receive X10 House Code 'L'  Unit Code '7' Command '3 - On'
Finally
Summary
The thing to notice in the second one is that the 'If' condition is only dependent on L.7.11 (off) and L.7.3 (on). Therefore this program will only turn the light on/off if an On or Off is received; bright/dim/status request/etc. have no effect because they are not part of the 'If' condition.
One difference between the first and second solution is if the 'Then' action is long running. The second solution handles it properly, but the first does not. In this case, to make the first solution equal to the second, you would have to add a 'Stop Program' as in this modified example:
Program1:
       Repeat Every  1 minute
          Wait  30 seconds
Finally
Program2:
       Stop Program 'Program1'
Finally
Another difference is that in the Second solution, the light will only Turn Off if that program turned it on. In the First solution, it will turn the light off whenever it receives an 'Off' command, regardless of how the light was originally turned on.
Of course having just written out this explanation, this really does stoke the 'Else' vs 'Finally' debate. I guess thats one of the reasons we have a Beta for something like this.
The 'Finally' clause is executed, when the 'If' statement is no longer true.
Could a hover bubble noting this above statement be added to the "If" text so users could remember its function. Personally I can't remember ever learning about it in all the classes I took so it may be remote concept to most people.
Mark,
The debate to use Else vs. Finally is still open as such we a little hesitant doing cosmetic changes where a functional change is required.
