Exception Name: JavaNativeException Description: java.lang.NullPointerException
nolan11
Hello, I had to replace my PLM since my one I had died. I followed all the steps to get the new PLM up an running and seems to be working fine, but when I try and log into my ISY through my MAC I get an error seen below...
I have tried clearing my Java Cache, registering my ISY IP to Java, and still keeps doing this. I have also reset the ISY and PLM twice.
I am lost as to what to do next. Please help...I have attached a few screenshots
at sun.awt.SunToolkit.getSystemEventQueueImplPP(SunToolkit.java:1090)
at sun.awt.SunToolkit.getSystemEventQueueImplPP(SunToolkit.java:1085)
at sun.awt.SunToolkit.getSystemEventQueueImpl(SunToolkit.java:1080)
at java.awt.Toolkit.getEventQueue(Toolkit.java:1734)
at java.awt.EventQueue.invokeLater(EventQueue.java:1266)
at sun.plugin2.main.client.MacOSXKeyHandler.notifyFlagsChangedFromNative(Unknown Source)
User Info: (null)
0   CoreFoundation                      0x00007fff897e57bb __exceptionPreprocess + 171
1   libobjc.A.dylib                     0x00007fff9df52a2a objc_exception_throw + 48
2   CoreFoundation                      0x00007fff897e5709 -[NSException raise] + 9
3   JavaNativeFoundation                0x0000000109deb01a JNFCallStaticVoidMethod + 233
4   libnpjp2.dylib                      0x00000001286b0c57 flagsChanged + 72
5   SkyLight                            0x00007fff9abc1376 processDecodedEventRef + 113
6   SkyLight                            0x00007fff9abc0bc1 processEventTapData + 543
7   SkyLight                            0x00007fff9abda0be _XPostEventTapData + 261
8   SkyLight                            0x00007fff9abc094c eventTapMessageHandler + 137
9   CoreFoundation                      0x00007fff897654dd __CFMachPortPerform + 253
10  CoreFoundation                      0x00007fff897653c9 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE1_PERFORM_FUNCTION__ + 41
11  CoreFoundation                      0x00007fff89765341 __CFRunLoopDoSource1 + 465
12  CoreFoundation                      0x00007fff8975d435 __CFRunLoopRun + 2405
13  CoreFoundation                      0x00007fff8975c874 CFRunLoopRunSpecific + 420
14  HIToolbox                           0x00007fff88cfcf6c RunCurrentEventLoopInMode + 240
15  HIToolbox                           0x00007fff88cfcda1 ReceiveNextEventCommon + 432
16  HIToolbox                           0x00007fff88cfcbd6 _BlockUntilNextEventMatchingListInModeWithFilter + 71
17  AppKit                              0x00007fff873f35f5 _DPSNextEvent + 1093
18  AppKit                              0x00007fff87b038eb -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1637
19  libosxapp.dylib                     0x0000000114f003aa -[NSApplicationAWT nextEventMatchingMask:untilDate:inMode:dequeue:] + 124
20  AppKit                              0x00007fff873e7fbd -[NSApplication run] + 926
21  libosxapp.dylib                     0x0000000114f0014d +[NSApplicationAWT runAWTLoopWithApp:] + 156
22  libawt_lwawt.dylib                  0x0000000114e8d4b3 -[AWTStarter starter:] + 905
23  Foundation                          0x00007fff8b1c7f2a __NSThreadPerformPerform + 326
24  CoreFoundation                      0x00007fff8977c581 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
25  CoreFoundation                      0x00007fff8975d98c __CFRunLoopDoSources0 + 556
26  CoreFoundation                      0x00007fff8975ce76 __CFRunLoopRun + 934
27  CoreFoundation                      0x00007fff8975c874 CFRunLoopRunSpecific + 420
28  java                                0x0000000109c1d465 CreateExecutionEnvironment + 871
29  java                                0x0000000109c1918c JLI_Launch + 1952
30  java                                0x0000000109c1f4c2 main + 101
31  java                                0x0000000109c189e4 start + 52
32  ???                                 0x000000000000000e 0x0 + 14
Hi nolan11,
Please follow the instructions under MAC and specifically:
if you are using either Safari or Firefox, you can get to the download folder, please click on the button with a Down Arrow icon at the top right section of the screen and then click on admin.jnlp (inside the download folder).
Safari Users: If you do not see the Down Arrow button at the top right, please follow the instructions here to get the download button back on your Safari.
If you are prompted be prompted with a dialog warning you that you cannot open this application:
Go to System Preferences | Security & Privacy | General
Click on the open anyway button at the bottom
Hi nolan11,
Hello, I did all of that, the file Java file opens and then disappears.
Hi nolan11,
Do you still get the same error? You are welcome to submit a ticket (links below).
Yes I am, I will submit a ticket.
