how can I start over with my ControlLinc
I can't seem to get my old scenes deleted from my controlLinc and they keep happening. I've tried a factory reset of it and the switches that it controls and they continue to work despite this.
Here is the biggest problem: if I hit #4, it turns on four lights in a scene which is enough to blow the breaker and I have to go down to the basement to reset the breaker. frustrating.
Is there any way to get the isy to look for broken links and remove them in both the controllinc and in the switches that the controllinc controls?
You need to remove it from the ISY first, then factory reset it and then relink it back to ISY...did you try that?
Also, it should not blow breakers no matter what. This means that you have a circuit overloaded....you need to investigate that further. You likely have a problem there that should be corrected.
Eric
Hi someguy,
As Eric suggested, you should factory reset the CL and add it back to ISY. Furthmore, I do think the problem is actually in the responders to your CL. Would you be kind enough to do a restore on one of these responders and see if still responds to the CL. If the request fails, then would you be kind enough to let me know which version of SWL do you have?
