Motion Sensor 2842-222 v.24 Low Bat
I have several Motion Sensors 2842-222 v.24 and I have noticed that whenever the Low Bat status turns on. I can't reset it back to off even though I have replaced the battery.
The only way I have found so far that works is to delete the sensor and re-add it again to the system.
Has anyone else seen this issue? Is there something I am not doing that I should?
After replacing the battery, set the MS to linking mode and query it. Another solution is to use a program to update the sensor:
IN Front Hall Sensor
        Control 'IN / Devices / IN Front Hall-Sensor' is switched On
        Set 'IN / Devices / IN Front Hall-Sensor' Write Device Updates
I actually have the program disabled (to save the battery) and I run [THEN] when needed.
MS units are not capable of sending LowBatt Off, only On.
UDI has created a workaround by faking the Off in ISY. See Michel's post above.
