cmccartney Posted November 21, 2016 Posted November 21, 2016 Is there some way to send an email notification from ISY on each change to/from daylight savings? At the actual change, not just the scheduled date. The reason I would like this is that there are many things (clocks, etc.) around the house that need manual attention and we always forget one or two. An email to me and the wife with a checklist would be a great reminder. Craig
Michel Kohanim Posted November 21, 2016 Posted November 21, 2016 Hi Craig, Unfortunately not but I do like the idea. Let us discuss the sizing. With kind regards, Michel
stusviews Posted November 21, 2016 Posted November 21, 2016 The actual change is at 2AM. If you only need a checklist, why does it have to be at that specific time? Wouldn't the evening before or the morning after the change be adequate.
larryllix Posted November 22, 2016 Posted November 22, 2016 (edited) 2:00 AM happens twice in the same night, each year in the fall time change. Edited November 22, 2016 by larryllix
G W Posted November 22, 2016 Posted November 22, 2016 Put it on your calendar, add a delayed email, set an alarm in your phone. There are a dozen ways to do this already without having to create one that only a few will use. I'm Gary Funk and I approved this message.
cmccartney Posted November 22, 2016 Author Posted November 22, 2016 Michel, What do you mean by sizing? Gary, et al: The problem with using a specific time/date, "putting it on my calendar", is that the politicians tend to change the date(s) every so often, and only in some areas (countries/states...). This has happened twice in recent years, and many times, as I recall, over my lifetime. I was thinking of something a little more stable to reliably notify that a time change has occurred. Craig
paulbates Posted November 22, 2016 Posted November 22, 2016 V5 variables are not my specialty, but would there be some way to do it with an ISY program and the new date / time variable features in V5? Save the time to a variable hourly in one program based on date (Nov and March) and time ranges (1:00am to 3:00am) Do a compare hourly just after the hour, comparing the variable in another program bounded within a date (Nov and March) and time range (1am to 3am)? The idea is, within boundaries, I'd expect the variable after 1am + 1h = 2. If variable+1 <> 2 // (eg 3 or 1), I know that DST changed then: do a notification, .... Alternatively, write one program for each condition... when variable+1 = 3 or when variable+1 = 1 and have distinct notifications for spring and fall. That may not be exactly the right parameters, but something along those lines could work, for those that have worked this feature better than me. Paul
rccoleman Posted November 22, 2016 Posted November 22, 2016 The ISYData component of ioguy's NodeLink has a daylight saving time field. I asked for it and he quickly added the feature. You could use that variable as a heartbeat (detect a change) and trigger an email.
Teken Posted November 22, 2016 Posted November 22, 2016 On 11/22/2016 at 3:44 PM, rccoleman said: The ISYData component of ioguy's NodeLink has a daylight saving time field. I asked for it and he quickly added the feature. You could use that variable as a heartbeat (detect a change) and trigger an email. Can his program compensate for the OP's question of (IF) the Government decided to change *When* DST happen? I think the real question is when will the ISY Series Controller ever have a calendar to program for basic things. ie. You're able to select a date, date range, for a program. From casual reading I believe some members indicated v5 has a basic date option?
rccoleman Posted November 22, 2016 Posted November 22, 2016 Since it's based on the date from a 'real' OS (RPi or other), I would say 'yes'.
Teken Posted November 22, 2016 Posted November 22, 2016 On 11/22/2016 at 4:42 PM, rccoleman said: Since it's based on the date from a 'real' OS (RPi or other), I would say 'yes'. Just to be clear you are saying his program knows if someone changed DST a week earlier / later and than can compensate for that new data point?
Michel Kohanim Posted November 22, 2016 Posted November 22, 2016 Hello everyone, I consulted with Chris and he agreed to put on our requirements: an ISY System node which can have this property amongst others. With kind regards, Michel
rccoleman Posted November 22, 2016 Posted November 22, 2016 On 11/22/2016 at 4:45 PM, Teken said: Just to be clear you are saying his program knows if someone changed DST a week earlier / later and than can compensate for that new data point? As long as that information is conveyed to the OS, as I believe is the case for all major OSs, yes. It usually comes as part of an OS update when changes occur in different countries or regions around the world, and as you would expect your Windows, Mac, or Linux box to reflect the change, it would also be reflected in the node because it gets its data from the OS. Unless I'm misunderstanding the concern. Obviously it would be nice to have all of the fields from ISYData native to the ISY, so I'm happy to hear that UDI is amenable to that. Rob
Teken Posted November 22, 2016 Posted November 22, 2016 On 11/22/2016 at 8:13 PM, rccoleman said: As long as that information is conveyed to the OS, as I believe is the case for all major OSs, yes. It usually comes as part of an OS update when changes occur in different countries or regions around the world, and as you would expect your Windows, Mac, or Linux box to reflect the change, it would also be reflected in the node because it gets its data from the OS. Unless I'm misunderstanding the concern. Obviously it would be nice to have all of the fields from ISYData native to the ISY, so I'm happy to hear that UDI is amenable to that. Rob Hello Rob, Appreciate the clarity on the DST so in essence the application relies on the OS to be updated to know that condition should it ever change. I thought you were eluding to the fact I/O Guy's node application went out to the Internet similar to NTP Server to update and obtain the current stats.
cmccartney Posted November 23, 2016 Author Posted November 23, 2016 Michel, Sounds like a good approach. Thank you. Craig
builderb Posted November 23, 2016 Posted November 23, 2016 (edited) There is a dst flag associated with the datetime object in Python. Between that, and pyephem, I created a script that tracks those items, plus sun angles, etc. Basically my own version of NodeLink, since I'm having node issues with my ISY and the beta 5.x line. (FYI, beware the daylight_savings object. It only tells you whether, for a given location, DST exists or not, not whether is is DST time or not.) Edited November 23, 2016 by builderb
