December 2, 20169 yr Currently have 994i ir pro and would like to change to isy994i zw/ir pro. What would be the procedure?I already have the new isy and don't want mess things up. I have these modules: Portal Integration - MobiLinc Connect Uninstalled. Inactive ISY Portal Remotely connect through ISY portal. No port forwarding necessary. This is a subscription for 2 years and includes:Amazon Echo IntegrationIFTTTNetwork ModuleThis will deactivate MobiLinc Connect ModuleNote: Please upgrade to 4.3.26 or above before installing this module. After installing the module, please review ISY Portal Wiki. Expires: January 16, 2018 Installed on: February 14, 2016 Active A10/X10 Experimental Support Support for A10/X10 devices incorporated into the tree and managed through the Admin Console' Main tab rather than the Programs tab Installed on: December 7, 2012 Active Open Auto Demand/Response Module Thank you! Edited December 2, 20169 yr by CopyRon
December 2, 20169 yr All you need to do is buy the Z-Wave module and put it in the ISY. It's $44 and you can order here: https://www.universal-devices.com/sales/ I'm Gary Funk and I approved this message. Edited December 2, 20169 yr by GaryFunk
December 2, 20169 yr Besides purchasing the hardware you will also need to activate the Z-Wave module for $1.00. Edited December 3, 20169 yr by Teken
December 3, 20169 yr Author I bought the new ISY with ZWHow do install the new ISY?Or how do I migrate to it? Edited December 3, 20169 yr by CopyRon
December 3, 20169 yr Backup the old, restore to the new. If you don't mind the tedium, it's really best to start anew. Tools, Generate Topology will give you a list of all devices along with their Insteon IDs. Edited December 3, 20169 yr by stusviews
December 3, 20169 yr I don't think the portal will transfer, you will have to submit I support ticket for that. Sent from my Nexus 6P using Tapatalk
December 3, 20169 yr The modules will not transfer. Contacting UDI with the original ISY994i ir's uuid: and the uuid: from the replacement. They can transfer the modules from the original to the replacement. Edited December 3, 20169 yr by Brian H
December 3, 20169 yr Author Got it done! I intend to move my old ISY to my shop, so I purchased new modules. So far the home is working fine.
December 4, 20169 yr Hi Ron, Instructions for migration: http://wiki.universal-devices.com/index.php?title=ISY-994i_Series:Migrating_To_Your_ISY-994i With kind regards, Michel
