Problems with GeoFence
Hi everyone,
I'm brand new to ISY, switching from Vera, so I thought I'd post here, although it should probably be in the Mobilinc forum.
I'm having trouble getting a geofence to work with Mobilinc Pro. At first, using the ISY portal, Mobilinc would not create the state variable. Basically the exact same problem as in this post (everything else worked perfectly). So, like they did, I switched over to a direct IP connection and it created fine. Wrote a program to turn off the lights based on the state variable, works fine when you change the state of the variable manually. However, when I leave the "fenced area", Mobilink is not updating the state.
I think my question is probably more related to the portals. Can anyone point me to a quick primer on which portal does what? I see some parts of the wiki that say you can't use Mobilink anymore, other places say yes, Mobilinc doesn't say much, but one of the add-ons claims it works with direct IP or the Mobilinc portal... So confusing :/
I'm also using Amazon Echos, so that is important as well.
Thanks in advance,
Byron
Hi Bryon, welcome to the forums!
In the future it would be best to post Moblinc questions in that particular forum. The ISY is supported by many 3rd parties like moblinc, and those authors might only review their own subforums.
Wes, fyi @InsteonNut
Paul
