control backlight levels for A B C D on Keypadlinc 2334-232
For argument sake, I'm reality new to programming ISY and bought a 6 button Keypadlinc, so just playing with it trying to learn how it works.  Turning a lamp module on / off via the Keypadlinc D button works fine, button D lights when lamp module is on, but if any other scene turns on the lamp module, the Keypadlinc D button does not light up
Rather than list all the scenes involved, i created a simple test to checking status of the lamp module and attempting to turn on the light for the Keypadlinc D button
If i manually turn on the lamp module, the status of lamp module is checked and if on ... turns the pots = on, and off accordingly ... However, I cannot get the Keypadlinc buttons to turn on/off following the status of the lamp module
Family Room KPL D
        Status  'Tree 26.DD.BD' >= 1%
        Set 'Family Room Pot Lights' On
        Set 'KPL Family Rm FirePlace Light / FamilyRoom - D' On  2 / Off 1 (Backlight Level)
        Set 'Family Room Pot Lights' Off
        Set 'KPL Family Rm FirePlace Light / FamilyRoom - D' On  1 / Off 1 (Backlight Level)
cheers
jim
Create a scene and put the lamp module and the KPL button into the scene. Add the KPL button as a controller.
The only level you want for the lamp should be set withn the scene.
I did that and it works properly, however i would still like to know how to control the light levels for each button for other scenes i would like to write independent of scenes
KPL button LEDs can only be turned on and Off via  scenes.
Programs can set the brightness level of KPL button LEDs but all buttons have the same brightness when On. They are not individually settable.
Ok thanks for the clarification
I created a scene with just the KPL button and modified the program ... this works if anyone needs as a sample to control the light for a specific button
Family Room KPL D
        Status  'Lamp Module 1' >= 1%
        Set Scene 'KPL FamilyRoom - D' On
        Set Scene 'KPL FamilyRoom - D' Off
  • 1 month later...
I can not seem to find the "Set Scene" command, just the "Adjust Scene". I can turn the lights on but not the KPL button. This is what I have:
Garage Lights
IF
    X10 'A5/On (3)' is Received
   Set MB 'Closet Light KeypadLinc / 3D.B8.7A.D' On 15 / Off 0 (Backlight Level)
   Set 'Garage Scones ToggleLinc Rela' On
Hi Edgar, welcome to the UDI forums!
Its the "Insteon" selection under the Actions drop down, under the "Then" clause of the program. The scenes are listed towards the bottom of the devices.
Paul
Paul
Thanks Paul. Did not realized there were more options listed. Thanks again.
Edgar
