6-button, fanlinc and remote issues
I think I'm missing something simple that I just haven't found the right thing in the other threads about this.
I have two fanlinc, one 6 button wall switch and one 8 button remote.
The goal is to have the switch on/off be the lights
switch button A turn both fans on low
switch button B turn both fans on med
switch button C turn both fans on high
switch button D turn both fans off
remote button A toggle both lights on/off
remote button B toggle fans med/off <----this is where I'm having the most problems----
I have the other remote buttons set for other things.
Lights are mostly working, the remote gets out of sync but a second press gets it back in sync.
Switch buttons pressed direct where working correctly until I make the programs for the remote B toggle med/off
I made two programs but do I end up needing to make four? I'm trying to get around the sometimes needing two remote button presses to change the fan
program 1 "remote b button on" fan med
  status switch B is off
 and status switch D is 100%
 and Control remote B is switched ON
 Or Control remote B is switched OFF
then
 set Scene 'Fan med' on
program 2 "remote B button off" fans off
 status switch A 100%
 or status switch B 100%
 or status switch C 100%
and control remote B is switched on
or control remote B is switched off
then
 set Scene 'fans off' on
I've even tried a different thing and it keeps turning the fans off
if remote switch b is switched on
and status wall switch D off is not off
then set scene fans med
else
set scene fans off
Edited by thebrack
The remote is a controller only. It remains unaware of any scene/device changes. In toggle mode, each alternate press will send to opposite command  (on or off) of the previous press regardless of the state of any responders. A solution is to use 4-button mode or set the mode to non-toggle on and use programs to turn the scene(s) off.
