FortrezZ Mimo2+
Is anybody successfully using the Mimo2+ on version 5 and see both relays and sensors?
I am on version 5.0.10 and only see one binary and one multisensor.
I am able to set the configuration parameter for each relay but the ISY doesn't allow me to control both.
I am assuming it is just lack of support in the ISY at this time.
Any help would be appreciated.
Jason
  • 4 weeks later...
I would like this information as well.  I could not get it to work correctly on 5.0.10 but I think I got it to work a little on 5.0.4
Thanks for responding! I wanted to make sure it wasn't just a defective unit.
I guess in time it will get added to the ISY for full compatibility.
  • 2 months later...
Does any body have any experience with the  FortrezZ MiMO2+ Interface Module?  Or possibly a work around if it is not compatable?
Edited by KSchex
  • 4 months later...
Dang, just bought the mimo2+ hoping to use both relays. Currently on 4 series, will it work on 5? Dont want to bother upgrading to 5 unless it will work.
Thanks....
I too need the MiMO2+ capability.  Unfortunately only one in and one out show up on the ISY with V 4.xxx.  I am hoping version 5. is available soon and is fully compatible with the MiMO2+ and ZWave Plus devices.
Same as everybody else, unable to get relay 2 or sensor 2 to be identified in ISY 5.0.11b.  Relay 1 works fine, unfortunately I require both for my project
