Multiple questions about portals and android apps
I got a new Samsung S7 several months back and want to install an app for my Insteon lighting with my isy994i.  What seems to be the very best way to go?
Mobilinc or Agave?  Is Mobilinc more versatile?
I also got Alexa the other day and want to control my Insteon system with it.  I have read so much my head hurts.  If I have Mobilinc on my phone I need to purchase a portal but will I be able to use Alexa if I use mobilinc??
Can anyone point me in the right direction to find the info that I need to get all of this figured out?  The portal thing kind of confuses me right now.
Edited by ingeborgdot
Mobilinc for Apple and Agave for Android.
Sent from my SM-G950U1 using Tapatalk
Agave for Android, okay.  Now the portal thing.  Does Agave take up the same portal that Amazon Echo does?
Yes, they can share the portal.
Okay.  I read something about Mobilinc and Alexa having problems and you could not use the same port.
So, if I go with Agave, which package do most people buy?
You have the
all access pass - 99.99 Agave ISY
all access pass - subscription 1.99
basic limited access - 5.99
extended access (thermo) - 19.99
extended access (flora) - 19.99
extended access (portal) - 21.99
extended access (variables) - 19.99
I don't need any sprinkler control because my RainMachine has a great app already.
I want to be able to control my lights at home and away.  The thermostat I have is a Venstar and runs through my isy994i but I want something a little better so I might be switching thermostats soon.  Any suggestions on which package or what I need to make it work will be appreciated.  Thanks.
Agave has features being added to it regularly. If you buy the all access pass you are finished for the life of the app. Whatever features are added will be included. So it's up to you.
What would I need to purchase from the isy Universal Devices????
Portal is a good to have but not absolutely required if you know how to port forward. That being said, if you want Amazon Echo integration you need it.
Sent from my SM-N910W8 using Tapatalk
Is there a place I can go that find tutorials on what I will have to purchase in order to get both Agave and Echo?
