Does the Isym 994i accept HTTP commands
I have a big project that i will cambine Zipato stuff, this guys are willing to develop some driver for the Isy994i, they are asking me now if the Isy994i accept HTTP commands, does it?.
All of the Lighting Control will be Insteon..
Yes.  The ISY has a very powerful and compete RESTFUL interface among other methods of connectivity.  Full documentation can be found at: Full Web Services/REST SDK, Java SDK, and Documentation with Open Source UDAjax for the currently released firmware version.
Hope this helps.
-Xathros
If possible it would be nicer to look at integrating with the 5.x firmware which supports native nodes in ISY for your development pleasure.  As an example, you could look at how ioguys node servers work.  I have a CAI webcontrol board which shows as native nodes on ISY.  It does require a PC running to handle the interface, but if your device has more internal computing power you may be able to install the node server directly on it.  This would be discussed under "polyglot" link above.
Edited by apostolakisl
