Motion Detection Issues, again!
I know this has been discussed many times, but I cannot make my motion lights work properly.  Here is the setup:  I have 3 lights on my driveway (2 are motion sensing) and use a micro module in one, and a inline-linc in the other to sens the voltage from the motion sensor.  When either motion light is triggered, it should turn on all 3 lights.   After a wait of 7 minutes I expect the lights to go off.  But, due to the strange way the wait command works, I cannot make it work.  I tried to move the wait command to the second program, but still have issues.
Originally it was set up as 1 program with a wait statement which didn't work properly.  So, after reading many posts here, I split it up into 1 programs.
Here they are:
Motion LIGHTUP ON - [iD 0058][Parent 0001]
        'Light, Drivew, park, MODULE' Status is On
     Or 'Light, Drivew, Park, MODULE 2' Status is On
        Set 'Light, Front Corner, Outside' On
        Set 'Light, Drivew, park, MODULE' On
        Set 'Light, Drivew, Park, MODULE 2' On
        Wait  7 minutes
        $ParkMotion  = 1
After the light is switched on, then the following program should execute.
Motion LIGHTUP OFF - [iD 0059][Parent 0001]
        $ParkMotion is 1
        Set 'Light, Front Corner, Outside' Off
        Set 'Light, Drivew, Park, MODULE 2' Off
        Set 'Light, Drivew, park, MODULE' Off
        $ParkMotion  = 0
 Should this not work ok?  The lights seem to come on and never go off, or sometimes never go on at all.  This is not a communications issue.  It seems that sometimes the off program doesn't pick up the value of "1".
Any ideas?
Here they are:
        Wait  7 minutes
        $ParkMotion  = 1
        $ParkMotion is 1
        $ParkMotion  = 0
Any ideas?
Stop using status. They are cancelling your program running.
Go back to one program with a wait and then turn the lights off
...control MS.1 is switched On
OR
...control MS.2 is switched on
OR
...control MS.3 is switched On
....set Light1 On
...set Light2 On
....more?
....Wait 10 minutes
....set Light1 off
....set Light2 Off
.....more?
....never get here with control/switched
Also...for a variable to trigger a program it has to be an Integer variable type.
OR
OR
....set Light1 On
...set Light2 On
....more?
....Wait 10 minutes
....set Light1 off
....set Light2 Off
.....more?
The inline-linc does not show up in the list for control (it only shows up under STATUS).  Only the micro module does.  I'll try it and see.
Thank you!
Here's a program snippet, ISY firmware and UI 4.6.2. Both Control and Status are available. OTOH, if you're using a test version of the ISY, then you should so indicate.
        Control 'EX / Devices / EX Breezeway Rear' is switched On
     Or Status  'EX / Devices / EX Breezeway Rear' is On
This is the In-LineLinc:
I can't imagine UDI would have removed anything from v5 and without any of these modules I cannot attest to them having the switched/control construct but.....
Assuming you only have status triggering you can break this into two programs in order to isolate the timing cycle from a Off trigger stopping the Wait.
An additional trigger to On can reset the Wait 7 minutes, but now it cannot cancel the timer with a detected Off trigger.
Program.trigger
....Ms.1 ststus is On
....OR
....MS.2 status is On
....run (if) Program.cycle
Program.cycle (disabled)
....----    <--------- here you could put a time of day filter or logic to run alternative Else coding
.....set Light1 On
....set Light2 On
....Wait 7 minutes
....set Light1 Off
....set Light2 Off
