Isy not receiving commands
jaycanter
I have 994iZ/ir Pro for 4 or 5 yrs everything had been working. few days ago all my rooms with motion sensors quit working. So today i checked my programs and everything on timer has run but anything from motion hasn't for a few days. So i opened up event viewer set to level 3 and tried pushing a couple of switches nothing shows up. I can turn lights on and off but the isy isn't receiving any commands from switches or motion sensors but sends out commands. could it be a bad powerlinc where it sends but doesn't receive? I have a spare any tricks to replacing it to test.
Any help would be appreciated.
Jay
How old is your PLM? How may links does the PLM have (Tools, Diagnostics, Show PLM Links Table)? A low number indicates a failing or failed PLM.
when i just opened said failed to communicate with everything was talking hr ago. looked at plm info/status all zeros and says not connected. go figure orded spare last week for sale and was supposed to be here Saturday got pushed to tomorrow.
You're no dummy, just the opposite. What you did is not only valid, it's recommended.
Any time I have difficulty, my wife says, "Did you plug it in"? She's usually right B)
That doesn't instill us with confidence about your abilities.
Sent from my SM-G955U1 using Tapatalk
ok now im really confused i got my new plm and added it made sure right address then restored plm still not receiving any commands but i can send them. if i press a switch controlling another device it works but there is no traffic in the event viewer set on 3. does that mean my isy crapped out?
Do you have a recent backup of the ISY before you had the problem? What can happen is the ISY gets "polluted" by the empty PLM when it copies links from the PLM into the ISY.
If you do, restore the backup and then repeat the restore procedure.
If you don't, then you should be able to "Restore Device" to each device. A pain if you have a lot of devices, but it can be worked through. Try one or two devices and retest if the ISY is receiving messages.
Paul
The other possibility is electrical changes that might be near the PLM.
If you can't think of any I would submit a ticket to UDI. They are really good about helping debug problems where the regular diagnosis isn't working
Paul
Did you attempt to test the original PLM (link count) before replacing it?
Yes original had nothing new plm had 1 after restore. I just loaded a backup from last month and restoring the plm now. I even tried moving everything originally the plm has a dedicated outlet under a dining room table thats directly to fuse box as it's own circuit. That was so no  one could plug anything in without laying on the floor to go under the table. Lol
  • 1 month later...
So this is strange.  I deleted the rules I created for the ISY IP addresses, in Windows Firewall.  I opened the ISY console and it behaved as it did since the update.  This mean in about 30 sec. I received the logon screen, for the ISY.  I logged back on, and now it has remained connected for about 10 min.
Go figure.  Wonder if this will last ?
      37.6k
      376.3k
