Replaced Switch Not Working with Echo
I had a faulty Switchlink dimmer, replaced it with a new one and ran the "replace with" command in the iSY console - The Switchlink is part of a scene - When attempting to control via the Echo"Kitchen Lights On" all lights except for the new switchlink turn on - Also, in the console the new device has a "1011" next to it.
Any ideas how to get this working??
If Write Updates doesn't appear to do anything, select Restore first followed by Write Updates.
I just replaced two switches last week, once you get them worked out in ISY you'll also have to go into the Portal and add them and remove the old ones, then have the Echo discover devices.
That's true is you're controlling the device. It's not necessary if the replaced device is a scene member and you're controlling that scene, but there's nothing wrong with doing so B)
