Aspire RF9500
I am running 5.02, and have just purchased an Aspire RF9500 remote switch to control a wall switch.
The isy sees it as a remote, but I cannot do anything with it.
When I add it to a scene, it shows up as a responder
If I try to put it as part of a program, the only thing it can respond to is "is responding"
John
The only way to know if it's supported is to use firmware 5.0.10.
Sent from my SM-G955U1 using Tapatalk
  • 5 months later...
I have the same problem.  I bought the Aspire RF9500 to control the GE 14294 but the isy won't let me us it in a program to control the Aspire.  Any Ideas??
What firmware are you using? Unless you are on 5.0.10 or higher, thats probably why. If you are running later firmware, its a possibility it may not be supported. Michel could potentially answer that one.
