Help, I just noticed my weather module is not working
All the data fields have the value of zero.   The weather station isy is supposed to be connected to is working, but I'm not getting any data.  Please advise what I should be checking.  I has worked for several years.
Thanks in advance.
What version of firmware is installed on the ISY?
Sent from my SM-G955U1 using Tapatalk
Edited by Gary Funk
You need to be using firmware 4.6.2 both UI & Firmware.
The UI is running 4.6.2 but the Firmware is 4.3.18.  Where do I go for updating the firmware ?
