TrojanHorse Posted November 21, 2017 Posted November 21, 2017 Hi All, A long shot here, but I’m looking for green screw terminal plugs for the relays on my old GC-100 and thought this was a good group to ask. Looks similar to some of the other GC products, eg the IP2CC. Any ideas? Sent from my iPhone using Tapatalk
larryllix Posted November 21, 2017 Posted November 21, 2017 I think Amphenol made some green shell connectors.
TrojanHorse Posted November 21, 2017 Author Posted November 21, 2017 I think Amphenol made some green shell connectors. Thanks. I will look. To be clear, they don’t need to be green Sent from my iPhone using Tapatalk
TJF1960 Posted November 21, 2017 Posted November 21, 2017 Those look to me to be made by Phoenix, they made a lot of different configurations. Look up Phoenix connectors. If you don't have any luck searching measure the distance between the two pins and post back.
TrojanHorse Posted November 21, 2017 Author Posted November 21, 2017 ~4mm between pins. I’m having trouble finding ones that appear to fit the triangular shape of the top. Here are the best pics I could take Sent from my iPhone using Tapatalk
TJF1960 Posted November 21, 2017 Posted November 21, 2017 I was unable to find a good front view pic from Phoenix, I took a pic of a board I have using what looks to be the same receptacle as yours. The link to the receptacle is https://www.digikey.com/products/en?keywords=277-1221-ND The link to the plug is https://www.digikey.com/products/en?keywords=277-1161-ND They list these as 3.81MM pin spacing.
TrojanHorse Posted November 22, 2017 Author Posted November 22, 2017 Thanks TJF1960 Those look like they could work. I also reached out to Global Cache and they got back and said it’s a “BCP-381-2” and provided this link. Looks very similar to your suggestion. Thank you!! https://www.digikey.com/product-detail/en/phoenix-contact/5434926/277-11236-ND/3603730 Sent from my iPhone using Tapatalk
LFMc Posted November 22, 2017 Posted November 22, 2017 These look to me like the terminal block plugs that I have seen on the Smartenit.com IO devices. They allow you to unplug the TB wires without having to unscrew them. I don't have a detail picture of them, but you can see them on their web site at smartenit.com. They came on my EZIO8SA unit in the pic I found below. Here is a pic I found on google:
