Setting variable from Aeon Labs energy meter
e40
Hello,
I'm trying to set a variable using a network resource pointing at my Aeon Labs Z-Wave energy meter.
Here is how the node shows up:
<?xml version="1.0" encoding="UTF-8"?>
<nodeInfo>
<node flag="0">
<address>ZW008_143</address>
<name>ZW 008 Energy Meter</name>
<family>4</family>
<parent type="3">54812</parent>
<type>4.33.1.0</type>
<enabled>true</enabled>
<deviceClass>0</deviceClass>
<wattage>0</wattage>
<dcPeriod>0</dcPeriod>
<startDelay>0</startDelay>
<endDelay>0</endDelay>
<pnode>ZW008_1</pnode>
<sgid>143</sgid>
<devtype>
<gen>4.33.1</gen>
<mfg>134.2.9</mfg>
<cat>143</cat>
</devtype>
<property id="ST" uom="73" formatted="2030.52 Watts" value="203052" prec="2"/>
</node>
<properties>
<property id="TPW" uom="33" formatted="9.63 kWh" value="963" prec="2"/>
</properties>
</nodeInfo>
And this is how I set up my network resource.
GET /rest/vars/set/2/1/${sys.node.ZW008_143.ST.raw} HTTP/1.1
Host: 192.168.5.10:80
User-Agent: Mozilla/4.0
Connection: Close
Content-Type: application/x-www-form-urlencoded
Authorization: Basic ****************
I get a 404 when I test it...  Thanks in advance,
Hi e40,
Are you calling ISY from itself?
Does the same work if you replace the $variable with a static value?
Also, you can already set variables to device states in 5.0.11B in programs.
Hi Michel,
Yes, this network resource & variable is on the ISY itself.  What I'm trying to do is read the value from the energy meter, place it in a variable that I can view in eKeyPad to show current power consumption.
As a test, I changed the path to /rest/vars/set/2/1/12345 and it populated the variable to '12345' as expected.
Hi e40,
Please try sending that variable through email. Maybe the address is wrong.
In call cases, you do NOT need these acrobatics with 5.0.11B: you can simply save the status of a device to a variable and then reuse it.
Hello -
Yes, if I send myself a test email message with variable  ${sys.node.ZW008_143.ST.raw} it displays it just fine.  Interesting.
I'll take a look at the alpha...
Edited by e40
Hello -
The variable seems to work as expected in 5.0.11B, thanks.  I rolled back to 4.6.2 for now, eK Pro was showing the thermostat temps as "730" instead of 73.0 and wouldn't allow adjustments.
