Disconnect from Mobilinc Portal
agoltz
Hi There
Im seeing this in the error logs repeated over and over again. Is there any way to stop ISY from trying to connect to the mobilinc portal?
(in the admin console - it says Portal - Mob (rest of text cut off) - then REGISTERED and OFFLINE
Tue 2017/12/19 08:09:37 AM System -170001 [TCP-Conn] -3/-140002, Portal-Dispatch
Tue 2017/12/19 08:10:07 AM System -170001 [TCP-Conn] -3/-140002, Portal-Dispatch
Tue 2017/12/19 08:10:37 AM System -170001 [TCP-Conn] -3/-140002, Portal-Dispatch
Tue 2017/12/19 08:11:07 AM System -170001 [TCP-Conn] -3/-140002, Portal-Dispatch
Tue 2017/12/19 08:11:37 AM System -170001 [TCP-Conn] -3/-140002, Portal-Dispatch
Tue 2017/12/19 08:12:07 AM System -170001 [TCP-Conn] -3/-140002, Portal-Dispatch
Tue 2017/12/19 08:12:37 AM System -170001 [TCP-Conn] -3/-140002, Portal-Dispatch
Tue 2017/12/19 08:13:07 AM System -170001 [TCP-Conn] -3/-140002, Portal-Dispatch
Tue 2017/12/19 08:13:37 AM System -170001 [TCP-Conn] -3/-140002, Portal-Dispatch
