Kwikset Z Wave Add user problems
I am trying to develop a program where I can generate a door code for a specified period of time in user slot number 2 for my Kwikset 912 Z wave door lock.
here's the scenario:
I have a guest coming over that needs access to the house and my poor planning has left me unable to program the door ahead of time.
I want a program that:
with a button-initiated script from HomeAssistant sets a "RUN" variable to 1
and sets a "CODE" variable to a random 4 digit integer
when "RUN" = 1 AND "CODE" is not 0 THEN
**********Here is where I can't find a solution************
set USER 2 code to "CODE"
wait [specified time (one hour...)]
delete user 2 code
I can do these thing manually but can't find a solution to perform these actions via program or REST
Firmware: 4.6.2
UI: 4.6.2
Edited by Yakker
Interesting question.  I do not recall any program action that could modify the settings of a z-wave device.  In my specific case (schlage zwave lock) the only action I can perform is lock or unlock or query.
delete user 2 code
Firmware: 4.6.2
UI: 4.6.2
Hello I am considering purchasing one of these and your ability to set or change a code on the go is one of the features I am looking for along with setting an expiration time for the code. Have you had any luck getting this program set up or another way to go about it. I would assume the iOS mobilinc app only gives you the option of Open/Close with it.
Thanks.
