Stop all running programs
is there a way to stop all running program?
There are situations when I would like to stop all programs that are currently running to kind of 'reset' things to start new program
however, in thinking about this as I type, I couldn't stop the program that I use to stop all others.
I can create a program that stops programs one by one and that might be only solution
thanks
Put all programs into one folder you want to stop. Put a logic condition for the folder in place, and make it evaluate to False.
To add to Larry's great idea, you can have your programs in various folders, and have a condition like a variable called "stop" (= 1). Add that as a folder condition to each folder, and make sure its prefixed by an "or".
Keep your "stop" program at the root level so its not affected. You will want to initialize stop = 1 so your ISY works when rebooted (or check for 0 instead of 1)
  (stop condition)
  $Stop = "1"
  $Stop = "0"
( run program A if)
( run program B then)
Keep in mind that the ISY is event driven, so turning the "stop" variable to 1 will stop all of the programs... but changing it to 0 not start all of the stopped programs.. when their conditions are met they will start individually, or you might have to manually run the "ifs". Or add statements in the else to run key programs to restart them. I do something similar when my ISY restarts, I kick off certain key programs so values get populated, etc
Paul
Edited by paulbates
thanks and sounds like good idea in general.  However, in my case my different programs are already in different folders.  for example, I have a folder for Winter, Summer, NightTime and such.
but maybe given the suggestion I can change or rethink what I have done
thanks again
thanks again
Folders can be nested. Just drop your folders involved into another folder temporarily with a condition until you are done testing or keep them that way.
Unless you only want some of the programs in those folders to stop, then there is no need to nest folders.  Just add the condition to each of those folders.
For example, create a state variable "s.stop.programs"  In each of those folders put
s.stop.programs is 0
allow programs to run
*Note that if you already have other condtions for the folder, use an "or" to connect this condition.
Now create a program (that is not in any of those folders)
(whatever conditions you want to cause the programs to stop)
set s.stop.programs to 1
set s.stop.programs to 0
