Elk shortcut on home page?
apostolakisl
James,
Any chance we can get the ability to put an Elk shortcut on the home page?  It would definitely help with the WAF.
It would also be nice if the "overview" Elk page had the arm/disarm buttons on it rather than having to click the Elk shield (which is not intuitively a button at all).
Right now, it takes 4 clicks to get to the point I can arm/disarm my system, and one of these clicks is a drop down and another is clicking on the not-obviusly-a-button Elk shield.  It could be two clicks (open agave, click Elk shortcut on home screen) instead and it would all be obvious.  Right now you have to open a menu which requires a lot more visual inspection (especiallly if you are hitting that age where you need reading glasses).  Then you have to hit the Elk shield which is not intuitively a button at all.  Then a press and hold on the "arm" button.  I woudl prefer a press then confirm, again, more obvious.
Not that you can bolt through this stuff as it currently exists if you remember where it all is, but again . .. the WAF.
  • 4 months later...
