0.8.12 weather node names
Do I have to do anything special to get new names for the weather nodes?  I've restarted NodeLink, restarted the admin console, rebooted the ISY, Installed nodes from NodeLink and from the ISY, queried, etc.  I still see "Weather" and "Weather[2-5]" for my two Ecobees, and my understanding was that the nodes would be renamed to reflect that they're forecasts.
Rob
I did the same with no results either.
Try deleting the "Weather" nodes from ISY and then adding Nodes again from Nodelink.
Mine came back with "Current Weather", "Forecast 1" "...2", etc..
Note names may not be exact.
You may have to delete the nodes and then click on Nodelink to install the node again.
I can't be sure how,  as I have had many reboots and upgrades of NodeLink and ISY due to other problems in the last two days.
Not sure what the issue is, just rename them. Who cares what the hidden node name is?
Sure, I can rename them.  It wasn't clear from the release notes that the human-readable labels wouldn't change.
Human readable would change for any new nodes added. I don't change existing node names.
Yes just go to your nodelink admin page and turn weather off
then go to ISY and delete the weather nodes (only weather ones)
then go back to nodelink admin page and turn weather page back on
they come right in
That fixes it.  The confusion was human-readable vs. hidden node name, and I don't care about the actual node name.
