ISY 994i backup failing, could not retrieve file /conf/net/121.res
anyone else run into this? is it a sign the internal SD card is failing and needs to be replaced?
I went into network resources, and rewrote 121 (just deleting it didn't help) and then the backup was able to complete.
Thanks for any help!
I ran into a similar issue the other day. The backup would get to 49% - 5.RES and fail. I deleted that net resource entry (was just a test one) and was able to do a backup. I didn't need to telnet in as I just used the admin interface.
great, thank you!! isy interface says no bad blocks on the SD card, will be watching it carefully in case this is the beginning of the end :)
