Help with Program and maybe Wait command
Hello!
Trying to make a simple program that sends me an email immediately when a door is opened - easy enough... but the part that is stumping me is that I only want it to send me the email once every 5 minutes, or in other words only if it hasn't already done one in within the last 5 minutes.  The reason being that it's not a commonly used door, but occasionally I may go in and out of the door 5 times within a few minutes and I don't want 5 emails.   I assumed using the WAIT command after the THEN actions would do this, but I still got an email for every time the door was opened within a short period of time.
Also, important note that I don't want the program to only run every 5 minutes, as I do want the email immediately when the door opens, just not excessive amounts of times within a few minutes.
Attached is a screen shot of what I have (unworking) as of now.
Thanks in advance!
You have no commands after the Wait, so the program will wait 5 minutes and end without doing anything (unless the status changes).
Question: do you want the notification if the door is left open for 5 minutes or only if it opens and closes during that time?
You will need two programs to do this.
program 1
if
door is opened
then
run then program 2
program 2
if
blank
then
disable program 1
send email
wait 5 mintues
enable program 1
The "disable" approach is one solution.
Another is to use an integer variable, this allows implementation of the solution in a single program:
Notify on Shed door open - [ID 0115][Parent 001F]
        Status  'Shed Door-Opened' is On
    And $Integer.Notified_Shed_Recently is 0
        Send Notification to 'NR' content 'NR Shed Door'
       $Integer.Notified_Shed_Recently  = 1
        Wait  5 minutes
       $Integer.Notified_Shed_Recently  = 0
        Wait  10 minutes
       Send Notification to 'NR2' content 'Close the darn shed door already'
        Wait  5 minutes
Make sure you create the variable $Integer.Notified_Shed_Recently as an Integer, not a State variable, and "Init" is 0 (That is, value starts out as zero after a reboot).
        Wait  5 minutes
        Wait  10 minutes
        Wait  5 minutes
Just realize that this isn't a controlled wait time.  The program can keep retriggering with every change in the status of the shed door and theoretically never send an email beyond the first.  Unlikely for that to go on forever, but could easily go for a few hours depending on the usage of that door.
Edited by apostolakisl
Good catch!
This may be a desirable feature for the OP.
Each time the gate is changed open or closed, Else will run resetting the Else timer, effectively making the algorithm 5 minutes after the last gate change the next open will notify. Gate traffic will extend the time.
Good catch!
There are no Else statements.
I see the Else in the code example...
Oops, Nevermind.
Edited by DrLumen
There are several examples, I was referring to the OP. I should have been clearer.
Thank you all, I appreciate it!
I went with the option that APOSTOLAKISL gave in making two programs, as it was the easiest for a newbie like me to understand and duplicate.
it's working just as I wanted it to now.
Thanks again!
Thanks again!
Others have expressed some concern that should ISY reboot (a power failure) during the 5 minutes, then your program 1 will be stuck disabled.  Should you choose, you can fix this pretty easily
Program 1
door opens
Run Else program 2
Program 2 - set this to "run at startup"
- blank
enable program 1
Disable program 1
Send email
Wait 5 minutes
Enable program 1
Now, on the program summary page, set program 2 to RUN AT STARTUP
Run at startup will trigger the if clause at startup.  In the case of a blank if clause, then it defaults to running the then clause.  So, basically, program 1 will be enabled at startup.
