Limitations of Motion Sensor 2 (2844-222) with 4.6.2?
I am trying to use a new Insteon Motion Sensor 2 for the first time in my setup. I was able to link it successfully as a 2842-222 and it kinda works.
I can't get it to send On signals until after the timeout regardless of the options I set.  I really want it to only send On signals like I've done with several other of the older motion sensors.
Is this a limitation of using the newer motion sensor as used with 4.6.2?
Timeout: 0.5
​LED Brightness: 15
Darkness Sensitivity: 128
​Sensing Mode: Checked
​LED On: Unchecked
​On commands only: Checked
​Night only mode: Unchecked
Yes it is a limitation in 4.6.2.
Adding it as the earlier model Allows it to do basic functions.
Some here that also have a HUB. Have used the HUB to set the options and then add it to the ISY994i Module Tree.
Edited by Brian H
This is how I worked around the Motion Sensor II using the default settings...Note I am using 5.0.11C, so you may need to change the program to get it to work in 4.6.2.  This is how I run my two light switches and the motion sensor.  If the sensor sees motion, it turns lights on...once the motion sensor runs it's 30 seconds of ON and switches to OFF the Else statement of program 1 runs and will hold for 5 min with the lights on, if the sensor is triggered again within that 5 min window, the program again becomes true until the sensors timer runs out and that triggers the else statement again and starts a new 5 min timer.
The 2nd and 3 programs are for if someone manually turns the lights off, the lockout prevents the motion detectors ON state from making the first programs if statement true for a period of time longer than what the motion sensors own timeout of 30 seconds is set to.
The limitation here of course is you cant put the lights and the sensor into a scene, so there is a small delay between detection and lights.
First Program
Kitchen Motion On - [iD 0014][Parent 000A]
        'Kitchen Motion Sensor-Sensor' Status is On
    And $Kitchen_Dinning_Room_Lockout is 0
        Set 'Dining Room Lights' Fast On
        Set 'Kitchen Lights' Fast On
        Wait  5 minutes
        Set 'Dining Room Lights' Fast Off
        Set 'Kitchen Lights' Fast Off
Second Program:
Switch_Lockout - [iD 0011][Parent 000A]
        'Dining Room Lights' is switched Off
     Or 'Dining Room Lights' is switched Fast Off
     Or 'Kitchen Lights' is switched Fast Off
     Or 'Kitchen Lights' is switched Off
        $Kitchen_Dinning_Room_Lockout += 1
Final Program:
 Lockout_Loop - [iD 0015][Parent 000A]
        $Kitchen_Dinning_Room_Lockout > 0
        Wait  35 seconds
        $Kitchen_Dinning_Room_Lockout  = 0
Edited by Greg
Perfect! Thanks Greg, this is exactly what I needed and it works great.
Glad it is working for you!
  • 5 months later...
First Program
        Wait  5 minutes
Second Program:
Final Program:
        Wait  35 seconds
Hi, how would you add manual on and off function to this? for example if i were to manually turn the light on, i would want it to stay on indefinitely until i turn the switch off manually.
The way I do mine is to disable my program when the light is manually turned on and re-enable it when the light is manually turned off. The motion is also auto enabled after midnight
Edited by lilyoyo1
  • 3 weeks later...
I use a technique I saw here once... set the light at 99% on in the sensor programming and at 100% if the manual switch is triggered on. The sensors won't turn the light off if the light is at 100%. But upon reflection, I don't know why I didn't just use a variable to indicate whether they were turned on by the sensors or the switch.
Some seem to be traumatised by variables and fear their complexity.
Sent from my SM-G930W8 using Tapatalk
So the 99% trick works, as long as that doesn't scare the same people.
For me it would be the most simple and obvious, considering wondering what you did a year from now.
I have owned an Insteon Motion Sensor 11 for about a year now. I did get it to somewhat work with ISY994i ZW firmware 4.6.2 but limited. I have since updated my firmware to 5.01.13C and now I see all kinds of adjustments that are available. Does anyone know what all of these do and should I even use most of them. I just use it to turn on my lights in the family room when it see's motion. I did read the owners manual from SmartHome and it just gave me instructions on how to set it up on an IOS or Android device. I am seeing this in the Admin Console of my ISY 994i. Thanks so much for your help and support.
Insteon Motion Sensor 11.docx
Edited by jblackst5000
