PLM malfunction
This past weekend it seems my PLM has gone south.  I was receiving an error on 2 devices in the admin console.  Querying the devices did not rectify the issue.  Is there anything I can try short of replacing the PLM?  Currently all of my programs and devices are spotty.
Moshe
Check out the topic "Strange problem - looking for ideas".
This was PLM failure that progressed over many weeks.
My suggestion would be to try a factory reset on the PLM, and go through the PM replacement procedure.
I was finally convinced that my PLM had failed when it would not reset.
Jack
Jack -
Thanks for the response.  I am certain now my PLM has malfunctioned.  I am getting a zero count plus safe mode.
Moshe
Those are two strong indications of a failed PLM. Be sure to follow the instructions word for word when replacing the PLM. Fortunately, if you make an error, you can start anew. https://wiki.universal-devices.com/index.php?title=ISY-99i/ISY-26_INSTEON:File_Menu#Restore_Modem_.28PLM.29
If it is over two years and a few months old. That would be another factor in determining it has failed.
Along with the LED on the side sometimes  being dim or RED.
I am pretty certain it is way over 2 years old.
Moshe
I have replaced the PLM and all is good.  The only issue I have is that with one device I am unable to write the updates. I have tried restoring the device but still no luck.
The device is an on/off outlet.
Any ideas?
Moshe
Hi Michel -
I tried restore - it did not work.
Moshe
I think mine is going bad... but really weird situation
Started on sunday... I use door open/close sensors to detect if my garage is open. if open for 15 mins, I have a program set to trigger my iolinc to close the garage door. That day I noticed it going up and down over and over as if it wasn't getting the "closed" signal.. so it just kept toggling.
I unplugged the PLM for 10 secs.. and plugged it back in but it didnt help. Then I did an upgrade from 4.5 something to 4.6.2. My outside light programs were still working sunday night so I figured all was well. Monday I saw my side lights and patio lights turned off, but the front door light program didn't. I went to work and had the garage open for more than 15 min and it triggered the close script.
I double checked on Agave and it showed Closed for the door sensor. But then my neighbor calls me saying the door is open.
I login to the admin jnlp and none of my devices are able to be queried. says it could not communicate with any of them.
But...
1. My light timers are still working every night this week.
2. When I do a Tools->Diagnostics->PLM Info it shows Connected
3. When I do a Tools->Diagnostics->Show PLM Links table it goes out and is able to grab 86 of them and the addresses seem fine at first glance
4. Made changes to programs and everything seems to process fine. I see flickering lights on the PLM when I send commands
5. I did a reset of the PLM (plug in while holding set for 10 secs) and then restored modem. That actually gave me "some" of the devices back.. I can now query my front and back lights.. but not the side lights. All insteon dimmer 2477d switches. IOLincs are still not talking. Tried putting the door sensors in linking mode but it still not finding them.
So I bought a new 2312S and we'll see how that goes.. but it seems like the PLM is working in general. So maybe something else.
Also noticed that neither of my Access points are doing anything when I plug them in. No lights or anything. Held the set button down for some time and nothing happens. Tried hitting it 4 times really fast to enable phase switching mode.. still nothing. So think maybe they are both dead and possibly one has been dead for a while and the second one just died and maybe that is why I can't talk to anything. So I bought 2 more on ebay. Think I will buy a few more anyway.
Anyway.... things are a mess right now
If the 2443 Access Points are hardware 2.0 or higher. They are built on the same base 2413 PLM board. The hardware 1.? are on the older boards used in the 2412.
They can have the same power supply issues as a greater than two year old 2413S.
I had two go bad myself. I believe the LEDs where out out real dim and failed the built in communications tests. I rebuilt them with the same parts used in the long PLM repair thread. Both are now functioning again.
If you have more than 5 or 6 devices and a couple of KPLs, then 86 PLM links is actually a very low count
I often wonder if the access points are really needed any longer.  It would seem that the mesh network and powerline communication are sufficent for getting communications to all devices.
You can certainly unplug them and see. I still get use out of one in my garage to extend to 2 iolincs I have out there. It works ok without it, it works perfect with it based on level three diagnostics.
Paul
It may depend on your setup and modules.
Many of mine are power line only modules. With a few Dual Band  one in the mix. I still use them as the later ones dropped X10 and I still control them with an X10 HR12A Palm Pad remote.
For me a good working set of Access Points is needed. For the Insteon controls and a JV Digital Engineering XTB-IIR for X10. As it respects Insteon and does not try and scramble the Insteon commands.
Ok I got a new PLM... but I think it was some Frankenstein module sold on ebay. The sticker says "2412U" but it has an serial jack on it. And it does power the ISY when plugged in. So I think it was some refurb and they swapped the USB port out. But...
1. ISY goes into safe mode when I connect it and restore plm fails with cannot reset the plm
2. I tried factory reset which is supposed to turn the LED off after holding for 10sec and release. But on this one the LED flashes for about 4 mins
3. No matter what I do, ISY cannot communicate with it so I think its a dud.
Meanwhile, I went back to my old PLM and did a factory reset on it. Restored the Modem and in the event viewer, some things look better than before. I added 2 new working access points to my house as well.
But I think the problem is actually the hops. Looking at the event viewer log, most of my devices are showing hops left :0
What's odd about that is my PLM is on my main floor, literally 10-15 feet from 2 IOlincs (1 communicates, 1 doesn't), 3 switch lincs (1 communicates, 2 don't) an On/Off module, 2 Keypadlincs, and a dual band Lamp module (only 1 month old) which also acts as an access point/mesh repeater. Everything is on that floor and well within range of both Mesh and powerline. I also have some X10 motion sensors going through a TM 751 which has been working fine.
So I don't know why I'm running out of hops
Event Log for restore of PLM looks good:
Quote
02/27/2018 12:57:11 AM : [D2D EVENT   ] Event [36 75 C6 3] [ST] [0] uom=0 prec=-1
Tue 02/27/2018 12:57:11 AM : [  36 75 C6 3]       ST   0
Tue 02/27/2018 12:57:16 AM : [        Time] 00:57:16 0(0)
Tue 02/27/2018 12:57:40 AM : [  16 87 74 1] Restoring PLM
Tue 02/27/2018 12:57:40 AM : [  13 85 E6 1] Replacing PLM links (locally and in PLM)
Tue 02/27/2018 12:57:40 AM : [  13 85 E6 1] Replacing PLM links Successful
Tue 02/27/2018 12:57:40 AM : [  13 86 AF 1] Replacing PLM links (locally and in PLM)
Tue 02/27/2018 12:57:40 AM : [  13 86 AF 1] Replacing PLM links Successful
Tue 02/27/2018 12:57:40 AM : [  17 D4 23 1] Replacing PLM links (locally and in PLM)
Tue 02/27/2018 12:57:40 AM : [  17 D4 23 1] Replacing PLM links Successful
Tue 02/27/2018 12:57:40 AM : [  20 BD 44 1] Replacing PLM links (locally and in PLM)
Tue 02/27/2018 12:57:40 AM : [  20 BD 44 1] Replacing PLM links Successful
Tue 02/27/2018 12:57:40 AM : [  21 65 57 1] Replacing PLM links (locally and in PLM)
Tue 02/27/2018 12:57:40 AM : [  21 65 57 1] Replacing PLM links Successful
Tue 02/27/2018 12:57:40 AM : [  27 AF 68 1] Replacing PLM links (locally and in PLM)
Tue 02/27/2018 12:57:40 AM : [  27 AF 68 1] Replacing PLM links Successful
Tue 02/27/2018 12:57:40 AM : [  29 BF 4B 1] Replacing PLM links (locally and in PLM)
Tue 02/27/2018 12:57:40 AM : [  29 BF 4B 1] Replacing PLM links Successful
Tue 02/27/2018 12:57:40 AM : [  29 DC 18 1] Replacing PLM links (locally and in PLM)
Tue 02/27/2018 12:57:40 AM : [  29 DC 18 1] Replacing PLM links Successful
Tue 02/27/2018 12:57:40 AM : [  29 E9 48 1] Replacing PLM links (locally and in PLM)
Tue 02/27/2018 12:57:40 AM : [  29 E9 48 1] Replacing PLM links Successful
Tue 02/27/2018 12:57:40 AM : [  2C F5 7C 1] Replacing PLM links (locally and in PLM)
Tue 02/27/2018 12:57:40 AM : [  2C F5 7C 1] Replacing PLM links Successful
Tue 02/27/2018 12:57:40 AM : [  31 6B FC 1] Replacing PLM links (locally and in PLM)
Tue 02/27/2018 12:57:40 AM : [  31 6B FC 1] Replacing PLM links Successful
Tue 02/27/2018 12:57:40 AM : [  31 E5 8B 1] Replacing PLM links (locally and in PLM)
Tue 02/27/2018 12:57:40 AM : [  31 E5 8B 1] Replacing PLM links Successful
Tue 02/27/2018 12:57:40 AM : [  32 2A 6B 1] Replacing PLM links (locally and in PLM)
Tue 02/27/2018 12:57:40 AM : [  32 2A 6B 1] Replacing PLM links Successful
Tue 02/27/2018 12:57:40 AM : [  36 75 C6 1] Replacing PLM links (locally and in PLM)
Tue 02/27/2018 12:57:40 AM : [  36 75 C6 1] Replacing PLM links Successful
Tue 02/27/2018 12:57:40 AM : [  36 CD 69 1] Replacing PLM links (locally and in PLM)
Tue 02/27/2018 12:57:40 AM : [  36 CD 69 1] Replacing PLM links Successful
Tue 02/27/2018 12:57:40 AM : [  36 FF 21 1] Replacing PLM links (locally and in PLM)
Tue 02/27/2018 12:57:40 AM : [  36 FF 21 1] Replacing PLM links Successful
Tue 02/27/2018 12:57:40 AM : [  36 FF 7E 1] Replacing PLM links (locally and in PLM)
Tue 02/27/2018 12:57:40 AM : [  36 FF 7E 1] Replacing PLM links Successful
Tue 02/27/2018 12:57:40 AM : [  49 21 C1 1] Replacing PLM links (locally and in PLM)
Tue 02/27/2018 12:57:40 AM : [  49 21 C1 1] Replacing PLM links Successful
Tue 02/27/2018 12:57:40 AM : [  49 22 75 1] Replacing PLM links (locally and in PLM)
Tue 02/27/2018 12:57:40 AM : [  49 22 75 1] Replacing PLM links Successful
Tue 02/27/2018 12:57:40 AM : Reset PLM
Tue 02/27/2018 12:57:44 AM : [RST-ACK     ] 02 67 06
Tue 02/27/2018 12:57:44 AM : [SET-CNF-RSP ] 02 6B 80 06
Tue 02/27/2018 12:57:44 AM : [All         ] Writing 212 bytes to devices
Event log with hops left at 0 for the failed modules that ran out of hops:
Quote
On/Off module (1 yr old)
Tue 02/27/2018 01:01:33 AM : [Std-Direct Nack] 2C.F5.7C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Tue 02/27/2018 01:01:38 AM : [INST-TX-I2CS] 02 62 2C F5 7C 1F 2F 00 00 02 0F C7 08 E2 01 00 00 00 01 00 01 0C
Tue 02/27/2018 01:01:38 AM : [INST-ACK    ] 02 62 2C.F5.7C 1F 2F 00 00 02 0F C7 08 E2 01 00 00 00 01 00 01 0C 06        (00)
Tue 02/27/2018 01:01:38 AM : [INST-SRX    ] 02 50 2C.F5.7C 16.87.74 A3 2F FF           (FF)
Tue 02/27/2018 01:01:38 AM : [Std-Direct Nack] 2C.F5.7C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Tue 02/27/2018 01:01:38 AM : [2C F5 7C 1  ] Link    7 : 0FC0 [E201000000010001] *Failed Writing [....000000......]
IOLinc (older). But there are 2 IOlincs in garage as I have 2 doors.. this one says it has one hop left and still fails. Maybe a bad module?
Tue 02/27/2018 01:01:51 AM : [Std-Direct Nack] 31.6B.FC-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Tue 02/27/2018 01:01:56 AM : [INST-TX-I2CS] 02 62 31 6B FC 1F 2F 00 00 02 0F EF 08 A2 08 13 86 AF FF 1F 00 B9
Tue 02/27/2018 01:01:56 AM : [INST-ACK    ] 02 62 31.6B.FC 1F 2F 00 00 02 0F EF 08 A2 08 13 86 AF FF 1F 00 B9 06        (00)
Tue 02/27/2018 01:01:57 AM : [INST-SRX    ] 02 50 31.6B.FC 16.87.74 A7 2F FF           (FF)
Tue 02/27/2018 01:01:57 AM : [Std-Direct Nack] 31.6B.FC-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Tue 02/27/2018 01:01:57 AM : [31 6B FC 1  ] Link    2 : 0FE8 [A2081386AFFF1F00] *Failed Writing [A2081386AFFF1F00]
Tue 02/27/2018 01:02:43 AM : [Std-Direct Nack] 2C.F5.7C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Tue 02/27/2018 01:02:52 AM : [INST-TX-I2CS] 02 62 2C F5 7C 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0
Tue 02/27/2018 01:02:52 AM : [INST-ACK    ] 02 62 2C.F5.7C 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06        (00)
Tue 02/27/2018 01:02:53 AM : [INST-SRX    ] 02 50 2C.F5.7C 16.87.74 A3 2F FF           (FF)
Tue 02/27/2018 01:02:53 AM : [Std-Direct Nack] 2C.F5.7C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Tue 02/27/2018 01:03:02 AM : [INST-TX-I2CS] 02 62 2C F5 7C 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0
Tue 02/27/2018 01:03:02 AM : [INST-ACK    ] 02 62 2C.F5.7C 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06        (00)
Tue 02/27/2018 01:03:02 AM : [INST-SRX    ] 02 50 2C.F5.7C 16.87.74 A3 2F FF           (FF)
Tue 02/27/2018 01:03:02 AM : [Std-Direct Nack] 2C.F5.7C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Tue 02/27/2018 01:04:20 AM : [INST-TX-I1  ] 02 62 2C F5 7C 0F 11 FF
Tue 02/27/2018 01:04:20 AM : [INST-ACK    ] 02 62 2C.F5.7C 0F 11 FF 06          LTONRR (FF)
Tue 02/27/2018 01:04:21 AM : [INST-SRX    ] 02 50 2C.F5.7C 16.87.74 A3 11 FF    LTONRR (FF)
Tue 02/27/2018 01:04:21 AM : [Std-Direct Nack] 2C.F5.7C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Tue 02/27/2018 01:04:21 AM : [D2D EVENT   ] Event [2C F5 7C 1] [ERR] [1] uom=0 prec=-1
Tue 02/27/2018 01:04:21 AM : [  2C F5 7C 1]      ERR   1
Tue 02/27/2018 01:04:25 AM : [INST-TX-I2CS] 02 62 2C F5 7C 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0
Tue 02/27/2018 01:04:25 AM : [INST-ACK    ] 02 62 2C.F5.7C 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06        (00)
Tue 02/27/2018 01:04:25 AM : [INST-SRX    ] 02 50 2C.F5.7C 16.87.74 A3 2F FF           (FF)
Tue 02/27/2018 01:04:25 AM : [Std-Direct Nack] 2C.F5.7C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Tue 02/27/2018 01:04:34 AM : [INST-TX-I2CS] 02 62 2C F5 7C 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0
Tue 02/27/2018 01:04:34 AM : [INST-ACK    ] 02 62 2C.F5.7C 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06        (00)
Tue 02/27/2018 01:04:35 AM : [INST-SRX    ] 02 50 2C.F5.7C 16.87.74 A3 2F FF           (FF)
Tue 02/27/2018 01:04:35 AM : [Std-Direct Nack] 2C.F5.7C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Tue 02/27/2018 01:04:44 AM : [INST-TX-I2CS] 02 62 2C F5 7C 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0
Tue 02/27/2018 01:04:44 AM : [INST-ACK    ] 02 62 2C.F5.7C 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06        (00)
Tue 02/27/2018 01:04:45 AM : [INST-SRX    ] 02 50 2C.F5.7C 16.87.74 A3 2F FF           (FF)
Tue 02/27/2018 01:04:45 AM : [Std-Direct Nack] 2C.F5.7C-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Tue 02/27/2018 01:04:49 AM : [D2D EVENT   ] Event [2C F5 7C 1] [ERR] [0] uom=0 prec=-1
Tue 02/27/2018 01:04:49 AM : [  2C F5 7C 1]      ERR   0
Tue 02/27/2018 01:05:19 AM : [INST-TX-I1  ] 02 62 29 E9 48 0F 11 A0
Tue 02/27/2018 01:05:19 AM : [INST-ACK    ] 02 62 29.E9.48 0F 11 A0 06          LTONRR (A0)
Tue 02/27/2018 01:05:23 AM : [D2D EVENT   ] Event [29 E9 48 1] [ERR] [1] uom=0 prec=-1
Oddly on subsequent plug/unplugs of the PLM.. different modules seem to work at spurious times. Even when the ISY admin panel can't talk to it, the timers I have set for things like the iolincs both function correctly. All 3 switchlincs turn on every night automatically. And at times I am able to interact with the devices through Agave... other times they time out.
Seems like maybe some spurious noise interfering or something, but nothing changed that I can think of. Maybe I'll buy a filterlinc module and see if that helps.
Edited by dsstrainer
If the unit you just got. Is a 2412U with a Serial Port daughter board swapped in.
It would be  a power line only and not a Dual Band module. Also depending on age. 417 or >2000 Link Database slower memory on daughter board.
If you compare the units weight. The 2412S is much heavier. As it has a power transformer power supply. The 2413S has a much lighter switching power supply.
The Developers Guide for the old 2412S.
Hold Set Button for at least ten seconds while  plugging it in.
LED on steady external  memory on daughter board found.
Blink six times. No external memory found. Link Database is 32 if memory serves me.
If you got this from Amazon was it sold by them or a Amazon merchant?  I  have seen some indications not all the merchants are on the up and up.
Edited by Brian H
Add Information
Nah this was on ebay.. sold as refurb... I guess I got what I paid for.
One other thing I thought of.
If they put a serial board from a 2413S in it. At least it would have had the link database size of a 2413S and the faster memory. Though I don't know if a 2412 would take advantage of the faster memory.
Well it just doesn't work at all.. so it's no faster :)
50 minutes ago, Sub-Routine said:
IIRC, the U had a cat5 type port and the cable supplied was a USB to cat5.
Hmm. Well I have another 2412U but it was certainly a USB-B connector. I don't think the thing you said exists
See what happens when you get old?
It's been over 10 years since I used the U so...
It's probably in the box with my prototype ISY-26.
Rand;
Time does seem to fly by.
I have an early production 2412S where they used the serial board from the 2414S. Unused Real Time Clock chip, battery and larger ram use to store downloaded SALAD programs.
