March 6, 20188 yr I am using my ISY with a Fibaro Flood Sensor I bought off amazon. As you can see in my attached image, there is one device that shows two variables (status and battery life). I can only seem to use the status variable. How can I make a program tell me when the battery if low? Thank you!
March 6, 20188 yr Depends on what you want to happen. If you want a text, you'll need to set that up on the ISY as well as what message you want to send. The wiki has information on this. Go into the programs, choose the device and it will give you your options for the leak sensor. You would then choose the notify option to set up the alert. I'm not home right now so i can't screen shot the information but the isy does allow you to receive a low battery alert for this sensor. Edited March 6, 20188 yr by lilyoyo1
March 6, 20188 yr Author 3 minutes ago, lilyoyo1 said: Depends on what you want to happen. If you want a text, you'll need to set that up on the ISY as well as what message you want to send. The wiki has information on this. Go into the programs, choose the device and it will give you your options for the leak sensor. You would then choose the notify option to set up the alert. I understand that, but it doesnt show up as an option in "condition" under the program I am creating. It gives me one condition for both status and battery level, it wont let me choose the battery life.
